Weird steering
Old Oct 9, 2024 | 03:31 PM
Gustheobsford's Avatar
Gustheobsford
Weird steering
I have a 1992 f150 4x4 and I just put 33x12.50 tires on it and 2 inch wheel spacers but now it feels like it’s pulling all over the place I toed it in a little more but it didn’t really seem to help so I’m not sure if I didn’t toe it in enough or if it might be something else.
Old Oct 9, 2024 | 07:13 PM
Conanski's Avatar
Conanski
Wider tires alone will produce more wander as those tires put more leverage on the steering over uneven road surfaces, and 2" spacers exaggerate that even more.
Old Oct 9, 2024 | 08:08 PM
Gustheobsford
is there anything I can do to make it less noticeable?
Old Oct 9, 2024 | 09:06 PM
Junktownbill99's Avatar
Junktownbill99
Take the spacers out
Old Oct 10, 2024 | 05:52 AM
Gustheobsford
The only issue I have with that is I need the spacers so they don’t rub
Old Oct 10, 2024 | 09:01 AM
1Butcher's Avatar
1Butcher
Then put in the right size tires
If you got any wear in the steering components, wider will just make the symptoms worst. If your truck is like every other truck on the road, you got 30+ years of wear on the stock parts.
Might be costly, but I would replace all the wear components, including the steering box. Buy the good stuff.
Old Oct 10, 2024 | 09:06 AM
My4Fordtrucks's Avatar
My4Fordtrucks
You put 12.5 tires on the stock wheels knowing that you would need spacers instead of buying wheel with the correct backspacing? I would expect 33” tires to be too big on a stock suspension.
Old Oct 10, 2024 | 09:14 AM
Gustheobsford
it’s got a leveling kit and a 3 inch body lift and custom offsets website said it would clear everything fine
Old Oct 10, 2024 | 09:16 AM
Gustheobsford
it wasn’t a bad amount of rub it was actually rubbing the same place my stock tires did, but I’ll definitely look into replacing my steering parts what parts would be best to start by replacing?
Old Oct 10, 2024 | 09:29 AM
R&RFord's Avatar
R&RFord
The hunt for slop is conducted by moving the steering wheel and observing what doesn't move when the steering wheel moves. You just go on down until you get to the wheels.
This can be a spendy venture and your lift and tires are not doing you any favors. Not saying to get rid of it. Just saying you got pay to play.
Old Oct 10, 2024 | 10:59 AM
Junktownbill99
33s fit just fine on my mostly stock suspension. However 12.5 is probably too wide, my 11.5s do rub, but it's manageable.
Old Oct 11, 2024 | 05:40 PM
94ZR580's Avatar
94ZR580
Toe in will cause wandering. Toe out is what would be needed.
Roady1269
Sep 21, 2023 08:12 AM
stumprider69
1997 - 2003 F150
Mar 12, 2012 10:05 PM
CounterMaker
Jun 29, 2009 07:19 PM
Todd316
Apr 29, 2008 03:01 PM
visegrip
Mar 3, 2001 08:05 PM
