Under hood courtesy light socket assembly
Old Oct 5, 2024 | 10:47 AM
thor363's Avatar
thor363
Anyone have a line on the factory style under hood courtesy light socket assembly?
Thanks.
Old Oct 6, 2024 | 12:56 PM
Rainmaker1's Avatar
Rainmaker1
I would think Ford would have them as NOS. The hoods on the Excursions and Superduty's are all the same from at least 1999 to 2007. If not check wrecking yards. Besides that, they are pretty much worthless IMHO. If you want light, I'd suggest led's in strategic locations.
Old Oct 6, 2024 | 03:43 PM
John in OkieLand's Avatar
John in OkieLand
the light from that thing is useless.
forget about it, get a Harbor Freight light with a Magnet on it,
about ~$5 bucks last I remember.
two of those will light up the moon.
https://www.harborfreight.com/search?q=portable+light
Old Oct 6, 2024 | 03:47 PM
01__Excursion's Avatar
01__Excursion
The Excursion part ( 1U5Z15702AA ) number is NLA, there appears to be an aftermarket for pennys.
https://www.npdlink.com/product/engi...es-bulb/215127
Old Oct 6, 2024 | 04:28 PM
Vinny G-the EX man's Avatar
Vinny G-the EX man
I used a KC cyclone led light and just spliced in a bulb adapter on the end of the light and pluged it into the existing light scoket where the factory bulb was. The light is round with a hole in the middle so I just removed a plug that holds up the hood liner, pushed it through the hole in the light and back into its existing hole on the hood Super bright and took all of 5 minutes for the complete install.
KC HiLiTES Cyclone V2 LED -...
Amazon Amazon
Old Oct 6, 2024 | 06:07 PM
callforfire's Avatar
callforfire
I stuck on some cheap 48 LED panels and wired into the switch. I didn't expect them to survive under hood conditions but so far so good.
Old crappy pics.
GLL Super White Energy-saving 5050 48-SMD GLL Super White Energy-saving 5050 48-SMD
The angle of the hood structure is just right for it.
Anonymous12
Jun 22, 2023 10:42 AM
machmedic
Mar 16, 2022 11:19 AM
jd1987
Aug 22, 2011 05:08 PM
99 f350
Feb 5, 2007 07:58 AM
