Rear Blinker
Old Oct 4, 2024 | 05:01 PM
hardgear69's Avatar
hardgear69
Rear Blinker
One of my rear turn signal bulbs not working, all other lights on truck work fine, replaced bulb did not fix. Check for codes(none) checked housing connection(fine) any other ideas.
Old Oct 5, 2024 | 07:18 AM
techrep's Avatar
techrep
what year truck you working on ? Have you checked fuse's ?
Old Oct 5, 2024 | 08:14 AM
hardgear69's Avatar
hardgear69
2018 f-350, have not checked any fuses, figured one light bulb would not be on a fuse. But which fuse would I be looking for?
Old Oct 5, 2024 | 09:07 AM
scraprat's Avatar
scraprat
Top Answer: 5
Originally Posted by hardgear69
2018 f-350, have not checked ked any, figured on light bulbs would not be on a fuse.
On my2016 each side rear blinker is on with that side brake light. Do you have brake light? If not check fuse. Passenger compartment fuses.
Looking at the 2018 owner manual I don’t even see turn signals in fuses other than trailer.
Old Oct 6, 2024 | 10:15 AM
hardgear69's Avatar
hardgear69
Any other thoughts.
Old Oct 7, 2024 | 05:06 AM
techrep's Avatar
techrep
I guess fuses were good ? does the front turn signal work ?
Old Oct 7, 2024 | 07:14 AM
hardgear69's Avatar
hardgear69
Looked at the fuse diagram did not see anything listed for turn signals, which fuse should I be looking for? It's only one bulb on the right bottom. If if a take top bulb from socket and put a screwdriver and jump contacts bottom bulb starts blinking.
drewthestu
Jun 18, 2014 10:52 PM
nateraz1
Dec 11, 2012 10:26 PM
Holtian
Dec 14, 2009 05:25 PM
brksb46041
15
Dec 12, 2006 04:38 PM
Goudey
1997 - 2003 F150
Jun 29, 2005 09:43 PM
