Sponsored by: Real Truck
Bump Steer?????
Old Nov 30, 2003 | 01:57 PM
Badford's Avatar
Badford
Unhappy Bump Steer?????
OK, i just finished my lift. i put a 2.5" hanger kit in the front with a 2" trac bar relocator bracket to put it back in line. and i put ford 4" blocks in the rear.
Now im getting some bump steer. and im stumped. the sway bars at stock location
anyone have this prob? with a fix?
thanks
Tony
Old Nov 30, 2003 | 03:27 PM
Yeti's Avatar
Yeti
Check out this old post:
BumpSteer
Old Nov 30, 2003 | 04:16 PM
Badford's Avatar
Badford
i have looked at alot of kits some come with longer sway bar end links and some don't are they needed?
so basically its all in the trac bar as far as the bump steer. i was thinking about the dual stearing stabilizer. aslo what about a new pitman arm is it needed for 2.5 " lift?
Tony
Old Nov 30, 2003 | 04:39 PM
Yeti's Avatar
Yeti
Bump steer is the toe-in or toe-out of the front wheels as the suspension goes from normal ride height through full bump (suspension system moves up) to full droop (suspension system moves down). Bump steer affects handling much as setting toe-in does. In other words, Bump Steer is when your wheels steer themselves without input from the steering wheel. The undesirable steering is caused by bumps in the road interacting with improper length or angle of your suspension and steering linkages.
I run longer swaybar links on mine, it's not good when the sway bar binds. As far a a stering stabilizer goes, it only comes into play when roads are bumpy or when trails are rough, they take the jolting out of the steering wheel. IMO,The dropped pitman arm will help the most, but I don't know if one is available for a 2.5 lift
olguy317
Aug 1, 2015 12:39 PM
jr2000sd
May 23, 2014 06:57 AM
tjbeggs
45
Oct 1, 2008 11:30 AM
Tony1790
Apr 14, 2002 03:26 PM
