View Poll Results: What could be wrong
Ecu got fried?
0%
Something i am missing completely?
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
Hooked up battery cabled backwards
Old Oct 1, 2024 | 04:56 PM
Birry123's Avatar
Birry123
1st Gear
F150 1984
I installed a battery and the put red on positive and black on negative. It turns out the mechanic my dad had work on it last replaced the cables with what he had left over I guess he swapped the colors. I have replaced the three modules by the battery because one of them smoked.
Key will turn on the dash but will not crank or do anything else can turn the engine at the solenoid but will not generate spark. Any help or insite is greatly appreciated
Old Oct 1, 2024 | 07:44 PM
FuzzFace2's Avatar
FuzzFace2
Welcome to FTE
Can you post up a picture or 2 of the 3 units you changed so we know what they are as I cant think i what they are?
It will also show if you got the wiring right as some have got wires mixed up.
Also check all the fuseable links as they are known to burn up when the battery is hooked up backwards.
Is the truck manual or auto transmission? If auto maybe the NSS also took a hit / burned?
Dave ----
Old Oct 1, 2024 | 08:00 PM
Franklin2's Avatar
Franklin2
See those slender rubber things in the smaller wires? That is what usually burns up when the battery is hooked backwards. They are fusible links and they power all the circuits in the truck. You may have one, two or several depending on the options ordered with your truck.
Old Oct 2, 2024 | 07:52 AM
Olds64's Avatar
Olds64
Check those fusible links as mentioned above. You should also check out the wiring near the passenger's fender. My truck failed to start in the past (didn't even have horn or lights) and it was just a connector that had burnt down.
https://www.ford-trucks.com/forums/1...se-holder.html
Magic#97
Oct 19, 2014 08:54 PM
oldworldwil
Nov 16, 2012 07:02 AM
bmf2030
19
Jun 12, 2007 10:47 PM
jonsmack
Jul 3, 2006 06:14 PM
1998XLT
1983 - 2012 Ranger & B-Series
Jun 2, 2002 04:26 PM
