Rattle accelerating
Old Sep 29, 2024 | 08:49 AM
Underdog33's Avatar
Underdog33
Trailering
Rattle accelerating
Hello. I own a 2008 f250 XLT crew cab with the v8 5.4 3v motor auto trans, 145,000 miles. At approximately 2,100 to around 3,100 rpm’s while accelerating rather normally I hear a rattling sound right up until it shifts . I did replace the exhaust manifolds thinking it was the rotted junk manifold gaskets that where very rotted. I’m hoping it is a heat shield Of some kind rattling but it’s hard to replicate without driving in that way.
i replaced the plugs and checked the rocker arms and they looked ok. I’ve watched YouTuber fordtechmakeuloco many of times so I figured too check those rockers.
the metal shrouds and clamps that hold them too the catalysts I have mostly removed due to them rattling right when I bought the truck and they were corroded and trash so I will try too see if something is wedged in thier or try to replicate a rattle in some way.
Old Oct 1, 2024 | 10:36 AM
G2IC_Wraith's Avatar
G2IC_Wraith
Underdog: I wish you luck tracking the sound down.
From this end, it is REALLY hard to know what rattle this could be as I am sure you know, it could be dozens of things.
I will share what has happened to mine here & there so maybe it helps, or it doesn't.
I assume you believe this is an "external" rattle meaning you think it is outside the engine.
Before I replaced both cats, 1 of them had a shield rattle & I am pretty sure the media in the driver's side cat was bouncing inside.
After the cats were replaced & things "loosened" up, the lip of one of the new cats was so close to the frame rail that it would make a VERY noticeable rattle & you could feel it.
You mentioned you already looked at the exhaust manifolds / gaskets. Those metal gaskets can make some really annoying noises once 1 or 2 of those manifold bolts breaks.
There is a very large heat shield above the muffler under the bed & the brackets can get rusted causing the shield to bounce on top of the muffler.
I am sure there are many others, but these are just a few that have annoyed me over the years.
Old Oct 2, 2024 | 08:30 AM
Underdog33's Avatar
Underdog33
Trailering
thank you for the input, all very helpful! Update- transmission inspection cover was rattling.
Pickupmanx2
Dec 8, 2024 10:52 AM
Underdog33
Oct 2, 2024 10:59 AM
Bronx Jimmy
May 16, 2011 02:38 PM
FUDF250
Apr 30, 2006 06:47 AM
Octane
1997 - 2003 F150
Nov 29, 2005 11:05 PM
