2022 6.7 Power Stroke and CP4 Issue
Top Answer
10-24-2021, 05:39 AM
2. One would find it necessary to ask FoMoCo about the *why* because any answer here is just speculation on anyone’s part.
Ignorance on the part of the owner/operator is a large part of the issues. Do NOT use alcohol based additives. Keep proper fuel for the temperatures in the vehicle. ( Allowing the fuel to gel up in cold weather = pump is running dry). Do NOT add DEF to fuel tank. Things like that.
Some folks can’t sleep nights because they are too worried about the things they have read on the internet. These failures can and do happen; but IMHO they get way overblown on the ‘net. With all that; maybe diesel is just not for everybody.
Yes, 2022 does have the CP4…….No, it does not cause fuel contamination; but fuel contamination has a very highn probability of damaging the CP4 and related components.
The following 3 users liked this post by Desert Don:
The following 4 users liked this post by Sport45:
The following 11 users liked this post by Desert Don:
1. *MOST* 6.7 PSD’s never have an issue as long as the owner/operator puts clean fuel in, and does not add the wrong fuel or contaminants to the fuel.
In unfamiliar areas use fuel stations with high fuel turnover. Paying a few more cent per gallon is worth it for piece of mind.
Lastly, should a driver realize they made a mistake at the pump before they leave. Don’t start the engine, don’t even cycle the key into accessory mode. Pull the fuse for then fuel pump and call for a tow. Pulling the fuse will prevent the pump from priming the system and sending any contaminates into the pump.
The following 3 users liked this post by Sanspy:
I owned a custom ordered, brand new 2020 F250 Lariat Tremor with 6.7L Turbodiesel that I took deliver of in February 2020. It lasted 5 months and 7490 miles before the fuel pump detonated, stalling the truck while in motion and in the middle of Friday evening, 5-o'clock traffic. I barely managed to get the truck out of traffic without an accident. It took Ford 88 days to fix my truck, admittedly due to COVID. To those who think the problem is water in the fuel, I'm going to respectfully disagree. First, there's a water separator on the engine. Second, if it was water, I feel confident that Ford would not have covered my repair under warranty. Third, there's a reason both GM and Dodge have gone away from the Bosch CP4. Based on my reading of quite a bit of literature (including the class action complaint) and watching YouTube videos, the CP4 works fine when diesel fuel from Europe is used. Here in the US, the ultra-low sulphur diesel fuel seems to be the problem. I fully expect Ford will eventually go away from the CP4. When they do, I'll consider buying another one. I absolutely loved every single aspect of my F250 Tremor except one. Maybe I was just the unlucky one but I would definitely not operate a 6.7L diesel without using a fuel additive to provide lubricity. (Yep, that was an addition to my vocabulary as a result of my CP4 education.)
The following 3 users liked this post by HogWild2020:
I personally know 2 people with CP4s that detonated (one Chevy, the other ford, unk years) this happened to. One let dealer take B/O truck and wrapped up the debt into another diesel truck (Ram, with CP3), the other sold the B/O truck to a friend (he told him), and bought a decked out GAS 250. I know other people who haven’t had any issues with their diesels (all under 80k tho). The problem is REAL. The question is what are the chances it happens to you? I couldn’t find that answer anywhere, manufacturer’s are not going to release that data. What made me go with a gas 250 is; *IF* it happened to me The repair bill, 10k+, is too much, keep in mind it can happen again if repaired… Ram went to CP4 for 20’ and 21’, Ram just announced a full recall on the CP4s and is going back to CP3 (possibly slightly modified). This sealed the deal for me to go gas. I want to go camping with the family in the middle of nowhere, just us. Last thing we need is to get stranded in limp mode, grenade the CP4, bo emissions sensor, not to mention submerging a red hot turbo in a mud/water. I dont NEED the diesel capability, although i do WANT it. The 7.3 is avg while diesel at 15.3, its really not that much of a difference for my use. I do think the vast majority of dieselers CP4 performs just fine for at least 150k. I do not think its as common as the internet can make it seem. But if it does happen to you, its very expensive.
Also, I think the CP4 and modern emissions system problems are eventually going to close the premium resell value enjoyed by diesels. There is a reason a lot of people are trading “up” and OUT of their diesel trucks as the warranty expires. Word is getting out about the high cost for repairs to diesels. I couldnt find a decent used gas hd in my search, plenty of diesels tho. Sure less gassers were sold, but i see gas closing the gap, especially with these new transmissions.
I'm no expert, but if you dig a little deeper into the details of Euro diesel and US diesel you will find that our ultra low sulfur diesel has a higher max sulfur count than European diesel. You can verify, but I believe our standard is 15ppm and theirs 10ppm. So it's not that their diesel is a higher sulfur diesel, because it's not, but they do have lower lubricity standard value (lower is better). Here our max lubricity value is 520, Europe it's 460. Lower= better lubricity. I haven't yet looked into exactly how they increase the lubricity of their diesel compared to ours.
This is an old article but still relevant today. It doesn't include Europe but is an interesting read on the topic of lubricity in diesel.
TAKING THE MYSTERY OUT OF LUBRICITY | Fuel Oil News
