Sponsored by: Real Truck
Spark plug issue when removing
Old Sep 26, 2024 | 08:49 AM
kiltym's Avatar
kiltym
4wd High
In the process of changing out the spark plugs. Did the driver side top, all went smoothly.
Started on the bottom driver side front and unscrewed the plug. It was more difficult to remove and I did it as carefully as possible. Once I got the plug out I can see there is damage on the thread. These are original plugs.
When I try to thread the new plug, it goes in a bit, but then basically cannot insert any further by hand. Seems the threads are damaged a bit. Very frustrating as this is from the factory as the plugs are original.
I am not a pro mechanic, so what do I do now? I have put a little anti seize on the threads but still cannot get it anywhere near all the way by hand, and don't want to force it.
To make things more interesting, me and the truck are in Argentina.
Old Sep 26, 2024 | 01:30 PM
Eman85's Avatar
Eman85
Old Sep 26, 2024 | 01:57 PM
'65Ford's Avatar
'65Ford
Originally Posted by Eman85
They make a spark plug thread chasing tool, should be 14mm. I would gently start the tool with a little grease on the threads and clean the threads. https://www.amazon.com/Lisle-20020-L...7375352&sr=8-5
Agree with using a chaser tool...it's less likely to mess up the threads than using a regular thread tap.
Old Sep 26, 2024 | 03:29 PM
kiltym's Avatar
kiltym
4wd High
Thanks for the tip on this tool.
Only issue is I am in Argentina and finding one of these is unlikely. I have the correct tap now, that I could fine here.
My concern is this hole is blind and I cannot see what I am doing. Makes me nervous to say the least trying to run the tap through the hole while not knowing if I am straight on or not.
What about slowly, over and over again, using an old (good) sparkplug. Slowly pushing it a bit further with a rachet, then pulling it back out and cleaning it, and repeating over and over again....??
Thanks for any advice, as this way not a situation I accounted for since these plugs were installed by the factory.
Old Sep 26, 2024 | 03:36 PM
apache84's Avatar
apache84
The tap would be far best however in a pinch Ive taken bolts of like size/thread and cut a groove in it lengthwise of the threaded portion. The cleaner the cut so the edges are sharp the better as it acts like the flutes of a tap. But if you can thread a plug in by hand a bunch you should be able to do the same with the tap enough to know your in straight, yes?
Old Sep 26, 2024 | 04:27 PM
kiltym's Avatar
kiltym
4wd High
A bunch is perhaps a stretch of what I can thread a plug in. Enough so it stays in place, but not sure how far in it actually is. Maybe 2-3 threads if I had to guess. Going to get an extension made for the tap I have so I can use a rachet on it. Is a bit too short as-is to get it in the recess for the plug/hole with any certainty. I put the tap in a little turning very gently, stopped and took it back out, and it had some metal on it. So it was starting to cut, which makes be a bit nervous as I was not really into the hole far at all.
Old Sep 27, 2024 | 08:32 AM
apache84's Avatar
apache84
I feel for you. Those knackered up threads might be a killer considering the heads threads are so few. Be patient and hopefully all turns out good.
Old Sep 27, 2024 | 08:41 AM
lshort's Avatar
lshort
what year and engine?
Old Sep 27, 2024 | 10:01 AM
kiltym's Avatar
kiltym
4wd High
Its a 2016 with the 6.2L.
Traveler 3468
Oct 17, 2024 06:48 PM
Fishwithdave
Aug 17, 2023 11:30 AM
SoLidwire
3.7, 3.5 and 3.0 Duratec V6
Jan 27, 2023 04:40 AM
mikenc
2009 - 2014 F150
Sep 22, 2022 09:27 PM
griz4718
1983 - 2012 Ranger & B-Series
Feb 16, 2005 08:06 AM
