Sponsored by: Real Truck
SPARK PLUG NOT THREADING ALL THE WAY
Old Aug 17, 2023 | 08:28 AM
Fishwithdave's Avatar
Fishwithdave
3rd Gear
I need some advice! Changed my sparkplug on 2011 F250.. I started at #8 and worked backwards. No issues removing or installing until #1 plug. It will not thread all the way! Is there an easy fix? Never had issues before! Thought of force threading, retapping the hole.
Old Aug 17, 2023 | 08:57 AM
Akley88's Avatar
Akley88
top or bottom set of plugs? were you able to remove the plug?
Old Aug 17, 2023 | 09:29 AM
Mike1's Avatar
Mike1
If the old plug came out no problem without damaged threads then one would assume the new plug thread is damaged, Did you try a different plug or put one of the pld ones back in to see if it threads down all the way?
Old Aug 17, 2023 | 09:55 AM
Fishwithdave
3rd Gear
Bottom plugs. I did try other plugs and even tried to put the old one back. I did not see any damaged threads. I've tried tightening & loosening a but at a time but my gutt says to stop.
Old Aug 17, 2023 | 10:00 AM
Mike1's Avatar
Mike1
I would grab a bore scope if you have one available to look at the thread hole. Then use a chaser tap with grease on it to catch any filings that may come off.
Old Aug 17, 2023 | 10:06 AM
Fishwithdave
3rd Gear
Do you know the tap size? Just asking to make my life easier but I can find out if you don't know.
Old Aug 17, 2023 | 10:09 AM
Mike1's Avatar
Mike1
I do not, I thought I might have the same problem when I changed my plugs on my 03 5.4L but my only problem was dirt and crud in the plug wells. once I made a tool to cut all that stuff out, my plugs came out easy and went in easy.
Old Aug 17, 2023 | 11:30 AM
redford's Avatar
redford
FTE Leadership Emeritus
You're going to have to get some sort of bore scope into the hole to figure out the issue, otherwise you risk doing more damage to your head.
Hotpocket
Jul 20, 2020 08:31 AM
Plain Jane
Oct 8, 2011 04:50 PM
Dom1121
Escape & Escape Hybrid
Jun 15, 2009 01:48 PM
papajoemrt
1997 - 2003 F150
20
Apr 30, 2009 09:47 PM
shwagy357
General Automotive Discussion
Feb 24, 2005 11:45 PM
