5.0 issues
1. Pop on deceleration (sounds like near right front tire).-- Intake has been changed twice. Still pops on hills when it upshifts, especially when towing. I can shift to M and duplicate it with on/off throttle. I have seen some posts that describe mine perfectly. I reproduced the noise for the tech and he said he has never heard that noise before.
2. Typical rough shifting on curvy roads, clunking in driveline with on/off throttle. Especially bad going up mountain roads at less than 30mph. -- Reset active learning and it improved some. Also improved with new set of tires. Still having issues, but some better. Generally, does well on HWY.
I talked to service advisor, and she said if it isn't to the add mark and it is due a change it is good. She said she is not aware of Ford replacing engines anymore and that they stopped because it didn't correct the problems. I am concerned about what burning all the oil is doing to the engine. I called Ford and was told the answer would come from the tech regarding the next step.
My questions:
1. Does the reprogramming from the TSB negatively affect performance, particularly transmission?
2. Does anyone know of any other resolution of the popping issue and could that possibly be related to the reprogramming?
3. If there is no further assistance from Ford with the oil consumption, will using the Moly additives some people report success from affect the lifetime powertrain warranty I received when I purchased the truck?
4. Will a transmission service and filter change make any real difference with the clunky transmission?
Thanks for any insight.
I probably asked too many questions on my first post. A lot of members viewed it but no responses. I happened upon some Youtube videos addressing slip yoke issues. I greased the slip yoke on my F150's driveshaft and it seemed to make a huge difference in the clunkiness of the transmission performance. I am really pleased with the result so far.
The big question remaining: Is anyone aware of any fix for the popping(backfire) type noises that seem to come from the right side of the engine bay near the tire? The noise happens on acceleration with an upshift, especially from 3rd to 4th. There have been several threads mentioning it, but I have not found any that seem to have resolved the issue. I drove the truck with a tech today who I know personally. He said that with all the noises these trucks make, we would be chasing a ghost to try to find it.
Thanks.
The Hi Pressure fuel pump is located on top center of the passenger side Valve cover. II makes a clicking sound at times depending on the fuel pressure.
Remove the rubber cover and check it for mounting looseness or some issue.
It's driven off the Exhaust Cam.
Nothing else there but maybe an exhaust leak popping.
Good luck.
