Leaky Front Pinion Seal?
Old Sep 25, 2024 | 09:10 AM
WXboy's Avatar
WXboy
The front pinion seal must be starting to leak. The housing is wet and the U-joint there is also wet. I'm a little surprised that it's leaking considering that the pinion doesn't spin. I rarely ever use 4x4. So in theory the pinion should just be sitting there 99.8% of the time. Odd....
Anybody else run into this?
Old Sep 25, 2024 | 09:15 AM
senix's Avatar
senix
Did you look above that area to see if it is off the motor?
Old Sep 25, 2024 | 11:59 AM
WXboy's Avatar
WXboy
Yep. I mean, I'll check again. But it looks just like a pinion leak.
Old Sep 25, 2024 | 10:34 PM
Kameron Rice's Avatar
Kameron Rice
probably shimmed wrong, and makes a strain. When you out in 4x4 it vibrates slightly and causes it to leak.
my 2022 f350 had the rear already replaced due to axle shim issue.
typically the only time these pinion seals leak is, vibration, caused by bad universals, shim issue. Could be a bad seal but I’d suspect probably not especially if you have used the 4x4 some recently
Old Sep 26, 2024 | 12:19 AM
willynilly's Avatar
willynilly
its either gear oil or it isnt. smell it dude
Old Sep 26, 2024 | 07:54 AM
jimzpsd's Avatar
jimzpsd
Check the breather tube from the pumpkin housing, if its clogged or pinched it may be building up internal pressure, axle housings need to vent. Start using 4wd more often or simply lock in the hubs from time to time, saying you barely use 4x4 could be cause for a dried up hard rubber seal.
ranstl
2004 - 2008 F150
Jun 1, 2010 09:40 PM
buckshot047
Apr 3, 2007 04:10 PM
69_bronco
Nov 21, 2003 09:46 PM
dash riprock
Aug 23, 2002 07:13 PM
alpo23
May 8, 2002 08:12 PM
