Possible bad head gasket
Old Oct 5, 2024 | 01:07 PM
'89F2urd's Avatar
'89F2urd
Originally Posted by Anonymous12
No there is no oil in the coolant.
and you dont add coolant?
Old Oct 5, 2024 | 01:10 PM
Anonymous12's Avatar
Anonymous12
Very rarely. I haven’t filled it since I serviced the cooling system in June or July. It’s just now at the point I need to fill it up a bit it’s probably an inch and a half below the neck. But I chalked that up as normal, especially cause the stupid radiator cap doesn’t draw more coolant in after it cools off.
Old Oct 5, 2024 | 01:49 PM
seschenburg's Avatar
seschenburg
I see nothing wrong with that spark plug. You can find charts on the Internet with pictures of good, bad, and ugly plugs.
Get one of those cheap USB bore scope cameras for your phone or a laptop. Remove spark plugs. Pressurize the cooling system (autoparts stores will rent/loan the kit). 15-20 PSI should be enough. You don't want to exceed rated pressure too much. I think it's 13PSI for the typical cooling system in these trucks. Look in each cylinder for leakage.
Generally speaking you won't have leakage into the cylinder when it's running. Cylinder pressure will see to that. What you'll have is over-pressurization in the cooling system and the overflow bottle will fill up. One of those combustion-products-in-the-coolant tester kits can also help here, but the one time I used one it was inconclusive, so look for other clues. (My overflow was filling up. No smoke and no other clues were solid. Replaced the head gaskets and problem resolved.)
You can have leakage into/from the oil while it's running though. Milky oil or a sheen in the coolant can identify this happening. You might even be able to detect some dye in the oil if your light is strong enough and the leak is great enough.
Adding dye to the coolant can certainly help find external leaks. Giving the engine a good wash first is highly recommended. Two cans of engine degreaser, the foam type, will get it clean enough to find new leaks.
And, lastly, buying gas from a station with old tanks, or one that doesn't sell a lot of gas, or water in your own tanks, can also bring moisture into your fuel system. IOW, you may be looking at the wrong end of the chain for the weak link.
Old Oct 9, 2024 | 08:11 PM
Anonymous12
I did some testing. I pressure tested the cooling system and stuck a camera down the cylinder. I did see coolant and it did slowly lose pressure. So I then did a leak down test on that cylinder (it was TDC) it held 84/100 psi it was cold. So I believe it to be the lower intake manifold having a crack or something
Old Oct 9, 2024 | 10:06 PM
97SuperDuty's Avatar
97SuperDuty
As someone who has owned a bunch of older stuff and been broke through my 20s, another truck or vehicle absolutely does help.
That used to work on my wife when I had 3 or 4 cars and trucks. Now she won't fall for it...LOL
Old Oct 9, 2024 | 10:11 PM
97SuperDuty
My personal take, if you're gonna do it, do it right. And I think that is what the OP is saying. He wants to do it right, but wants to do it when he can better afford to do it right. That piston looks bad to me, if it was clean and there was a head gasket leak it might be safe to try and put a new head gasket on it, but I had a head off a Range Rover and I knew the head gasket was blown and I was getting coolant in the oil...Finally when it did give up the ghost, all the pistons still looked clean, so that doesn't give me the warm fuzzies on the pic posted. As mentioned, consider the short/long block and/or how long you expect to keep it. I wish I had kept that Range Rover now, I could have just dropped an engine in. All hindsight now...the plugs don't look too bad, but you will want to replace them and make sure wires are good. Then you're probably gonna want to replace the belts, and don't forget the water pump while you have access...I think we all know this game all too well...
Alan
gameover1974
Dec 6, 2015 09:35 PM
markal
Jun 5, 2006 01:01 PM
GrayRanger4x4
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Apr 5, 2006 12:21 PM
Narwhal
15
Feb 18, 2006 04:25 PM
