2017 2.7 EB with P0456 code
Old Sep 24, 2024 | 02:40 AM
Pbear74's Avatar
Pbear74
4wd Low
My check engine light came on recently and the coffee is P0456, very small evap leak. Where should I start troubleshooting?
Old Sep 24, 2024 | 06:53 AM
SpencerPJ's Avatar
SpencerPJ
I would start by cleaning the gas inlet area.
Old Sep 24, 2024 | 07:12 AM
projectSHO89's Avatar
projectSHO89
RE: P0456
Yep to Spencer's suggestion. Been addressing this every few months on my '10 Escape for the last couple of years. Use the supplemental fueling funnel to vigorously "funnel hump" the self-sealing flapper at the inlet. Add some WD40 and repeat a couple of times.
On mine, the issue pops up when the computer decides to run the natural vacuum leak detection routine, usually as the fuel level drops to between 1/2 to 3/4 tank of fuel AND the vehicle has been parked for several hours. The MIL sets immediately upon subsequent startup after the test runs and fails.
Old Sep 24, 2024 | 09:53 PM
Pbear74's Avatar
Pbear74
4wd Low
I will start there.
Today I filed up my tank and when I started the truck it was struggling to start and then was idling hard. It stopped after I started driving
Old Oct 3, 2024 | 11:59 PM
Pbear74's Avatar
Pbear74
4wd Low
Today as i was driving a humming sound started, it turned out to be coming from the gas inlet. When I parked I opened the gas door and it sounded like it was sucking air. I pushed in the flap and it got louder. After turning off the truck I pushed on the flap again and it realesed air. I figured it was the purge valve so it swapped it out with a new part, the test drive went well. No issues with humming anymore, I don’t have a code reader so I will take it down to jiffylube in the morning to have them clear the code.
jwsrules
6.7L Power Stroke Diesel
Aug 7, 2024 08:09 AM
MeTo
Jun 14, 2024 03:18 PM
Frank79
Dec 12, 2023 09:12 AM
chzuck
2004 - 2008 F150
23
Sep 21, 2022 06:25 PM
steve17bs
1983 - 2012 Ranger & B-Series
Jul 31, 2004 05:15 PM
