This is my first solid check engine light with this truck; code U3012. I cleared it and will see how things go? Anyone else experience this code? Any info would be appreciated. Thanks and have a good day.
I haven't see this but a quick google search came up with this:
I just got back from running some errands, about 85 miles. No light. I read the TSB 23-2077 for this issue and the guy's comment about him taking his truck in to get the program update. He mentioned his truck rarely does the sick crow sound after and no more light. Mine does it a lot. Hopefully I can get it done under warranty also???
I had the same on my 2021 and the dealer told me the light keeps coming back it’s a software issue goes working on it . They checked my batteries and other things same code keeps getting kicked out . Even new pcm still happening currently waiting on a fix from ford
U codes are communication codes, you will need to get a scope on the comms lines and start proper diagnosis.. This is not a case of using a scanner to fix..
I deleted the code on May 6th and it's not been back. I'm still going to get the TSB update on the 20th. I have a friend who has done electronic/electrical work for Ford as a career. It will be a good opportunity to pick his brain and check if he would be willing to tweak a few things?
