Code P1299 2016 F-150
Old May 24, 2022 | 10:19 AM
GenX Ford's Avatar
GenX Ford
1st Gear
I have a 2016 Ford F-150, 2.7L, Gas. Yestreday the Engine light and Red Coolant light Both lit up. Truck did not want to really go. No prior problems before hand. It is says Code P1299. Overhead cylinder temperature sensor. Parts store says they are 2 sensor. Truck is not over heating, but was a little low on coolant.
Old May 24, 2022 | 12:58 PM
JKBrad's Avatar
JKBrad
Welcome to FTE GenXFord,
This thread is about a 3.5 overheating, but maybe it will help you out. You could have a thermostat issue
https://www.ford-trucks.com/forums/1...ed-solved.html
Old May 27, 2022 | 06:49 AM
projectSHO89's Avatar
projectSHO89
Could be anything from low coolant, to a faulty CHT sensor to a sensor harness wiring concern to the PCM.
Start with the obvious issue of low coolant and fix that first.
Old Oct 5, 2024 | 02:26 PM
mford13's Avatar
mford13
1st Gear
Hi. What turned out to be the issue? I am having the same problem. Thanks.
gint279315
1997 - 2003 F150
Oct 28, 2021 09:05 PM
NorthCarolinaExpy
Feb 8, 2018 12:06 PM
Lofide20
1997 - 2003 F150
Jan 18, 2017 02:09 PM
Heavenword1
Dec 5, 2007 05:23 PM
hood
Modular V8 (4.6L, 5.4L)
Apr 20, 2003 01:22 AM
