Low oil pressure
Old Sep 23, 2024 | 07:26 PM
Twom's Avatar
Twom
1st Gear
Low oil pressure
A couple of months back, my head gasket blew. I got two new heads and put in a bigger cam while I had the heads off. I put everything back together, but now it takes about 5 seconds to start, and the pressure switch on the dash doesn't move until 1500-2000 RPMs. I've got a mechanical gauge in the port by the oil filter, and it's reading 8-10 at idle and goes up to around 30 at 2k RPMs. The only spot I've seen leaking oil is the corner of the oil pan, which I'll have to reseal, but I don't think that will increase the pressure. I've seen people online running 20 PSI idle and also seen that if it's running, it's got enough. Should I look at anything else, or should I just drive it/let it run for a while and see what happens? Added a video of pressure gauge from idle to around 2k rpms
File Type: mp4
Old Sep 23, 2024 | 07:59 PM
Tpayne621's Avatar
Tpayne621
The stock oil pressure gauge is just a 7psi switch. So according to ford anything over 7psi is "normal" and reads normal on the gauge in cluster. Never had actual working low pressure oil gauge on one so not sure what they are known to run at really.
therigwelder
May 29, 2022 02:41 PM
BCHauler
Feb 5, 2009 10:46 PM
rsylvstr
1997 - 2003 F150
Aug 24, 2007 04:45 AM
89ranger2.9
Oil & Lubrication
May 16, 2007 12:38 AM
donniezyea
Apr 19, 2006 10:15 PM
