Do I have a problem...?
Old Feb 5, 2009 | 08:43 PM
BCHauler's Avatar
BCHauler
The oil pressure gauge hasn't worked in my truck for a while. Needle never moves, just stayed pinned below L. Today, I replaced the oil and temp gauges with some from a working cluster. Now, the oil pressure reads mid range when I am on the throttle, but drops to nothing when I take my foot off the pedal. I've read about the oil pressure gauge being a glorified idiot light but, is this normal behavior? My truck has at least 350,000 kms. but seems to run just fine. The history of the truck is unknown, but I've owned it for 9 months now and have put on probably 8000kms. Do I need to drop the pan and check the pickup, do I need to change out the sensor for a sending unit?
Advise is appreiated.
Old Feb 5, 2009 | 08:59 PM
Conanski's Avatar
Conanski
Start with the oil pressure switch, a motor with no oil pressure is pretty noisy so I doubt that's your problem.
Old Feb 5, 2009 | 09:05 PM
1966Tbird's Avatar
1966Tbird
i would put a manual gauge on it and see how much pressure you have
Old Feb 5, 2009 | 09:09 PM
PJF95's Avatar
PJF95
I agree with Conanski. No oil pressure and that thing would be really noisy at idle.
If you are really nervous go get a 30 dollar mechanical oil pressure gauge. It will tell you immediately if you have anything to worry about.
A good rule of thumb is 10 lbs of pressure per 1000 RPM. Although at idle that kind of goes out the window. I have seen idle pressure as low a 3 lbs and the engine still had plenty of pressure the instant it came off idle.
Long story short, if it isn't noisy, and it shows pressure while driving, don't sweat it. Just drive it and enjoy.
EDIT: Beaten by 1966Tbird!
Old Feb 5, 2009 | 09:21 PM
Old93junk's Avatar
Old93junk
Probably bad sender unit, Conanski is right, it would make a bad racket if oil pressure was really bad.
Old Feb 5, 2009 | 09:28 PM
BCHauler's Avatar
BCHauler
I should add that I just changed the oil and for the first time used 5w30 instead of my usual 10w30. Not sure if thinner oil affects pressure.
Old Feb 5, 2009 | 09:59 PM
Old93junk's Avatar
Old93junk
Might be part of it, I would stick with 10w30 in a big American V8. I have seen with mechanical gages big differences in PSI readings just by changing from one brand of oil to another of the same weight.....Still think its just the oil press. sending unit, I have had plenty go bad over the years.
Old Feb 5, 2009 | 10:46 PM
BCHauler's Avatar
BCHauler
I have always used 10w30 in all of my older v8s. Just this time I noticed the sticker on the rad support says 5w30 so I figured I'd give it a try.
Ok, thanks for the tips. I'll check the pressure sending unit. Did I read that it's threaded into the block behind the ps pump?
