The original Carter carb on my 79 250 with 300 shaft base is worn out so i picked up a Chinese one for temp use until I found the time to dedicate on repairing the Carter.
Now the question I have is which of the following numbers are what you call the carb number. To be able to track down proper repair kit.
MFG By
Carter for
Motorcraft
Also has
Made in USA
on other side
numbers on body of carb 72899
on top section 6 2433 or COULD Be G 2433
on base 2656
Thank you, Alex
Reason: Add Could be G 2433
Single barrel carter on a 300 is going to be a YF or YFA. Carbs should have a metal tag on them, but most get tossed in the rebuild. Mike Carburetor parts will have a kit that will fit the YF or YFA.
68 Flareside240 , So, tag is long gone prolly 40 feet down in some land fill.. LOL
How do I tell a YF and a YFA. Just courious. I will contact Mikes for the kit.
Beartracks, The shaft play is the reason for the temp replacement until I had time to install bushings and rebuild the Carter. Real hard to obtain a good idle with the shaft leaks...
