Tire Size Questions
Old Sep 20, 2024 | 04:01 PM
Cuz-Pat's Avatar
Cuz-Pat
Tire Size Questions
I had my 2017 Ford F250 Super Duty XLT 6.7 Liter diesel leveled last week with a Rough Country 2" leveling kit with drop down track bar bracket. Now, I am wanting to do something on a tire size change just as soon as my present tires are worn completely out which won't be long. I am looking at going to a LT295/65R20 tire which is a 35.1" tire. Most likely going with Toyo Open Country AT III or the Nitto Terra Grappler G3.
When I change the tire size can my dealer re-calibrate the truck computer and put in this size tire so that my speedometer will be correct? Also, all 4 of my TPMS sensors are gone out, I'm guessing the batteries have crapped out in each of them. Do I go back with OEM or has anyone had success with an aftermarket sensor?
Thank you kindly for any help on these questions.
Old Sep 20, 2024 | 04:30 PM
ZooDad's Avatar
ZooDad
Retired guy fixn stuff
You need ForScan to get the correct tire size configuration
ZooDad
Old Sep 21, 2024 | 03:24 PM
BDWSD22's Avatar
BDWSD22
I've been using the Autel MX dual frequency TPMS sensors with great results for many years.
Old Sep 22, 2024 | 08:09 AM
Joe T's Avatar
Joe T
Forscan. Watch a YouTube video. You’ll have it done before you could drive it to a shop.
Also with that much lift look for a taller 295/65/20 if possible. Some get up around 35.5. Or a 325/60 or 35x12.50 on aftermarket wheels. But would look great with a 35.1 295/65/20.
If you have any right pull do +2.3 passenger side and +2.0 DS caster shims.
Good luck!
Old Sep 22, 2024 | 10:42 AM
satxuser's Avatar
satxuser
I am running that exact tire size on my 2019. A few months back I finally said WTH and made the necessary adjustments in Forscan. Watched some youtube videos first and took my time. In the end it was a piece o' cake.
Old Sep 23, 2024 | 08:50 AM
WXboy's Avatar
WXboy
For TPMS sensors, absolutely go to Rock Auto and buy the Schrader 20280 sensors. They work perfectly on the 2019 trucks with NO PROGRAMMING necessary.
Pyrate7
2015 - 2020 F150
Jul 4, 2024 03:55 PM
Jonesy0027
2009 - 2014 F150
May 29, 2016 09:15 AM
tpepper
Modular V10 (6.8l)
Nov 28, 2007 10:16 AM
zstyle01
Sep 7, 2007 06:30 AM
eysham
May 8, 2007 09:27 PM
