67 mx 3 speed help
Old Sep 20, 2024 | 12:25 AM
brevikF's Avatar
brevikF
Trailering
67 mx 3 speed help
The transmission leaks out of like 6 spots I need a gasket kit but I'm not sure what to buy, looking to re seal it.
Old Sep 20, 2024 | 12:43 AM
85e150's Avatar
85e150
Is this a 3 on the tree manual or an automatic?
Old Sep 20, 2024 | 09:23 AM
brevikF's Avatar
brevikF
Trailering
it's na automatic
Old Sep 20, 2024 | 09:41 AM
85e150's Avatar
85e150
One source:
https://transpartsonline.com/TRANS_P...sPartsType=FMX
From this thread:
https://www.ford-trucks.com/forums/1...e-or-swap.html
Older MX or newer FMX?
https://globaltransmissionparts.com/...ruise-o-matic/
https://www.ebay.com/shop/cruise-o-m...c+transmission
I think you will find most kits are some kind of "rebuild" kit with some of the clutch parts etc.
Given the nature of the beast, if you are taking it apart, best to replace things that are worn and be done with it.
Have you rebuilt an automatic before?
Old Sep 20, 2024 | 11:17 PM
brevikF's Avatar
brevikF
Trailering
I haven't done any transmission work before. Thank you for your help. I'm not really sure on if it's a new or old trans. I'm 17 it's my first truck.
Old Sep 20, 2024 | 11:37 PM
85e150's Avatar
85e150
I recommend you have it serviced at a transmission shop. You'll have to research shops.
Does it drive and shift correctly?
Old Sep 22, 2024 | 10:03 AM
brevikF's Avatar
brevikF
Trailering
It drives ans shifts alright it just leaks atf out of most of the seals. I can't afford to take it to a shop, they want like 3k.
Old Sep 22, 2024 | 07:58 PM
85e150's Avatar
85e150
I do not recommend taking it apart yourself. Guys who are experienced wrench spinners come on here from time to time after the DIY transmission rebuild and ask why it won't work.
Is the major leak at the tailshaft and the pan gasket?
If you fixed those two would it be tolerable?
The tailshaft seal requires a "T" shaped tool to pop it out. Pan gasket just a little patience and clean up.
https://www.harborfreight.com/seal-p...vent_id=183642
Old Sep 24, 2024 | 12:39 AM
brevikF's Avatar
brevikF
Trailering
The main leak is the rear main and the pan. But it also leaks out of the linkage I believe. I rebuilt the motor I just don't know to much about the transmission.
Old Sep 24, 2024 | 01:00 AM
85e150's Avatar
85e150
Do you mean the tail shaft when you say "rear main?
Old Sep 24, 2024 | 02:16 AM
brevikF's Avatar
brevikF
Trailering
Where the motor meets the tranny it leaks out of the bell housing
Old Sep 24, 2024 | 07:14 AM
fe390pc's Avatar
fe390pc
If you already rebuilt the engine, you have the knowledge needed to re-seal the trans. Yes its not easy but doable. Sounds like the input shaft seal to the torque converter is bad, also doing the output shaft seal and pan gasket will reduce the leakage significantly. Look on youtube for videos, they can be very helpful. As for what trans you have the 1967 it depends on what engine you have. is it a 6 cylinder or an 8 cylinder? Can you get some pictures? Is it the original engine?
Old Sep 24, 2024 | 09:17 AM
brevikF's Avatar
brevikF
Trailering
Its a 360 fe, thank you for your help
Old Sep 24, 2024 | 11:03 AM
fe390pc's Avatar
fe390pc
OK, then the trans is either an FMX or a C6. You just need to see which one it is and go from there. Engine looks good so I have confidence you can do the seals on the trans with no problem!
Old Sep 25, 2024 | 05:18 PM
brevikF's Avatar
brevikF
Trailering
67 f100 transmission swap/help
I have a 360 motor that i just rebuild and i realized that it doesn't have the cooling lines that go from the transmission to the block. The transmission is a FMX 3 speed auto i believe. Is there a way to re route the cooling lines or should i just swap a c6 into there. If swapping the tranny is a better option what does that process look like. Any help is much appreciated in over my head a little bit.
