Need ECM help
Old Sep 19, 2024 | 05:56 PM
josiewales's Avatar
josiewales
Need ECM help
I have a '94 F250 with 7.5 L E4OD that is still shifting hard, so I'm thinking I need a ECM but am having problem understanding what me "calibration code" is. Here is the door sticker..Can someone tell me what ECM I need ?
Old Sep 19, 2024 | 06:13 PM
Blurry94's Avatar
Blurry94
Why do you think the ECM is the reason it's shifting hard?
Is the 'OD OFF' light on the shifter blinking and/or did you check for codes?
Old Sep 19, 2024 | 06:31 PM
Scndsin's Avatar
Scndsin
Plugging in your calibration code in the FTE search box:
https://www.ford-trucks.com/forums/1...-up-hills.html
Answer Blurry's question though before doing anything rash.
Old Sep 19, 2024 | 08:33 PM
josiewales's Avatar
josiewales
OK, checked the dipstick and found the fluid is red and up to between the holes in the stick and below the hash marks, with the temp just warming up. Then used the code reader and got 111, 10, 128, 452, 556. and the OD OFF light is off constant.
I'm confused, do the trans codes come out of the computer thru the reader or thru the OD light ?
Old Sep 19, 2024 | 09:27 PM
Blurry94's Avatar
Blurry94
128: MAP vacuum has not been changing – check vacuum lines
452: Vehicle Speed Sensor (VSS) problem
I'd start troubleshooting the reason these codes are present.
Old Sep 20, 2024 | 08:05 AM
manicmechanic007's Avatar
manicmechanic007
With a speed sensor code, the trans will hunt for shift
Your processor will not know road speed, and the trans will shift hard and at the wrong times
Your processor should have a LZJ tag, it's best to remove your processor and verify the numbers
When I replaced my processor for an intermittent engine miss concern, my trans started shifting better
Make sure the wiring to the connector is good before replacing your VSS
Those wires like to break right at the connector
Replace with a Motorcraft VSS if you need a new one
If you have a NGS you can read that VSS pid on your 1994
Old Sep 20, 2024 | 09:24 AM
Scndsin's Avatar
Scndsin
VSS wiring can also be damaged by dual exhaust conversions. (melting)
Also, the magnetic pick-up on the VSS can be contaminated by metal particles.
The toothed ring on the ring gear can dig into the VSS sensor if the bearings in the axle are excessively worn as well.
hcowthr
Mar 13, 2024 12:05 PM
Firs
17
Jan 18, 2023 10:16 AM
Troylj
Jun 16, 2022 07:56 AM
ShindaChinmoku
31
Aug 17, 2019 09:04 AM
OldRed460
Computer Chips & Tuners
Apr 12, 2005 09:14 AM
