07 E350 Rear sway
Old Sep 18, 2024 | 10:00 AM
Nef831's Avatar
Nef831
3rd Gear
07 E350 Rear sway
My friend has and E350, recently was pulling a trailer when all of sudden rear starting swaying reallly bad like death wobble . They recently rebuilt the whole front end . New tires. But still does the same thing at whatever speed . You’re driving when all of sudden the rear sways . He said feels like if he’s drifting. He did mention although he got an alignment after rebuilding the front he still had constantly move steering to go straight. He’s currently working on changing the steering gearbox but it’s hard to find a used one . He did mention they put in new driveshaft and they also checked rear diff. Oil was clean ,gears looked good. But the rear left wheel did have some play to it. Van has a all new shocks too , rear leaf springs look fine also. Everything seems so strange to me, it does not have a rear sway bar and it never has , it never swayed like that before he said
Old Sep 18, 2024 | 10:33 AM
tabijan's Avatar
tabijan
It sways all the time or only when towing?
What was replaced in the front end?
Sixto
07 E350 5.4 198K miles
Old Sep 19, 2024 | 08:02 AM
manicmechanic007's Avatar
manicmechanic007
Left rear wheel has some play in it?
Get that fixed straight away
Do not let it run with loose wheel bearings
That and tire pressure and call me in the morning
Adding a sway bar will help
Too much caster is your trouble when towing and the rear end sags
So, 10 ply tires, pumped up, and go slow
My van does it too
Crazy, but towed a trailer with a 97 F150 on it with my half ton 94 van
Did the same thing and I had a mountain pass to deal with
Go slow, 50-55 tops, then no shimmy or death wobble
Old Sep 19, 2024 | 11:14 AM
Mike1's Avatar
Mike1
If pulling a trailer, you really shouldn't be going faster than 55mph as they tend to sway at higher speeds. If he had sag on the rear, then that takes weight off the frontend which contributes to the sway. Rear wheel play, probably a bearing going out, it will contribute to the sway, under inflated tires maybe? It will contribute to the sway.
I rented a Uhaul 24ft box truck and a car trailer to finish moving my mother from Florida to Mississippi, Truck wasn't really load too bad, had rider mowers and such in it, I was towing a 65 Chevy drop top., I could barely do over 55mph without the trailer sway starting, Needless to say I kept it at 55mph not wanting to tell my mother that her $40K convertible decided to flip and roll. Other factors to consider are also the front sway bar bushing were they changed? Are the new shocks all the way around good shocks or something he bought off ebay on clearance sale? Big difference in quality. Lastly, tell your friend to fix what it broke first like the loose wheel. then move forward from there.
Old Sep 21, 2024 | 09:49 PM
Nef831's Avatar
Nef831
3rd Gear
The front suspension was changed , tie rods , ball joints , shocks , steering rack. Pitman arm etc. he says it never swayed before not even while towing
Old Sep 21, 2024 | 09:53 PM
Nef831's Avatar
Nef831
3rd Gear
He says now it sways even with out towing , even when riding empty. Crazy thing he said it never swayed crazy like that not even when towing
Old Sep 21, 2024 | 10:14 PM
tabijan's Avatar
tabijan
Could a tire be going flat? Revisit the front suspension. Maybe something wasn’t tightened or a new part is a dud.
Sixto
Old Sep 22, 2024 | 06:24 AM
manicmechanic007
If that is the case have someone else re align it, and give you a printout to show you where it is now, and what they did
Tell them of your wander complaint and they should set the toe to a positive number
That positive toe set will negate or eliminate the wander if all the front end parts are tight, and the front tires are decent
When you get a new van, the toe is set to +1/8 or +3/32, that chews the front tires up on the outside, but they drive like a dream
To negate tire wear, most alignment techs will set your van at zero or -1/32 = toe out
That builds in a slight wander
I drive my van around with my toe set at -1/16 and my tires wear flat, and my van wanders
I did alignments for 25 years before starting my own shop where now I do everything but
LiveFrom1977f150
Aug 14, 2018 12:42 PM
pawilkes
Jun 4, 2018 02:57 PM
JWA
Apr 17, 2014 10:19 AM
octaneforce
Dec 19, 2011 05:27 PM
2000navi
Nov 30, 2009 12:37 AM
