Rear Track bar?
Old Aug 13, 2018 | 07:41 PM
LiveFrom1977f150's Avatar
LiveFrom1977f150
Rear Track bar?
When im under heavy acceleration at highway speeds, my truck gets squirrelly and loose in the steering to where im counter steering from side to side. Not sure if this is a symptom of dog tracking or what. But its not comfortable at all when passing on the highway or even passing a horse and buggy on the back roads. I dont have a rear trackbar, just the leaf springs. Would adding a rear track bar with the leafs help at all? I plan on having a good alignment shop take a look at things. But im curious as to what i could to do to help prior to alignment.
Old Aug 13, 2018 | 08:02 PM
85e150's Avatar
85e150
I take it you don't have traction issues. Weak or broken spring on one side, causing the rear axle to wrap a little and get crooked as a result?
Rear track bar? Anti-roll bar, panhard rod, traction bar?
Old Aug 13, 2018 | 08:34 PM
LiveFrom1977f150
Im not breaking loose or anything. Nothings broken back there that i could see.
I dont i have any of those fancy things installed. Just a track bar in the front.
Old Aug 13, 2018 | 11:11 PM
85e150's Avatar
85e150
Like so?
Adding one to the rear won't help. I think you have a geometry problem somewhere in the suspension.
Old Aug 14, 2018 | 07:17 AM
LiveFrom1977f150
appreciate the feedback. I think your right.
Old Aug 14, 2018 | 12:42 PM
FuzzFace2's Avatar
FuzzFace2
Check the front spring bushing on the rear leaf springs.
If bad that would make it steer from the rear on and off the gas.
Dave - - - -
ETOWN55
Nov 17, 2015 10:36 AM
ReBilld
24
Mar 25, 2013 06:32 PM
glovemeister
Sep 16, 2012 10:52 AM
Rusty_Bits
Apr 22, 2010 05:32 PM
funkoptimus
Apr 8, 2005 03:50 PM
