Trans cooler help
Old Sep 17, 2024 | 08:20 PM
pdhulteng's Avatar
pdhulteng
Trans cooler help
I am installing a bigger trans cooler in the F350 and need some help on routing the lines. They were not routed through the radiator so I would like to go through the radiator and the cooler. Thanks in advance.
Old Sep 17, 2024 | 09:05 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Route from the front of the trans to the radiator cooler, then to the aux cooler that you're installing, then to the rear of the transmission.
Old Sep 18, 2024 | 09:49 AM
1Butcher's Avatar
1Butcher
Not a bad idea to use larger lines. A bit more work, but it's not that expensive to cobble up your own.
Old Sep 18, 2024 | 09:56 AM
novispecial's Avatar
novispecial
Trailering
You should also use a cooler that has one larger tube in it so trans fluid can flow in -20 weather.
Old Sep 18, 2024 | 10:26 AM
1Butcher's Avatar
1Butcher
Get the 4R100 bypass and get the 6.0 trans cooler if you really want to go all out. You will not have to worry about flow at -20
But why would I want to go out at -20F?
Old Sep 19, 2024 | 03:06 PM
pdhulteng's Avatar
pdhulteng
Because I live in Montana
Old Sep 19, 2024 | 03:07 PM
pdhulteng's Avatar
pdhulteng
It is a B M trans cooler.
Jason Taylor
Apr 21, 2024 10:01 PM
lud04X
Aug 15, 2016 09:21 AM
grec-o-face
Jul 14, 2012 01:42 PM
Bubba828
Apr 9, 2009 09:51 AM
cbremer
Apr 10, 2000 09:40 PM
