360 rebuild
Old Sep 17, 2024 | 05:03 PM
Thewon2141's Avatar
Thewon2141
4th Gear
360 rebuild
I’m looking for a good parts list for when I rebuild my FE 360 5.9
Old Sep 17, 2024 | 05:23 PM
85e150's Avatar
85e150
Welcome to FTE.
What kind of rebuild?
Stock?
Upgraded performance?
Have you ever rebuilt an engine before?
Old Sep 17, 2024 | 08:45 PM
Thewon2141's Avatar
Thewon2141
4th Gear
I used to rebuild Cummins 525’s in the corps so I am capable (I think).
Im looking to beef it up a bit new heads, cam, manifold, etc. just not sure what I can and can’t do if that makes sense… I know summit has kits but mostly for 390’s.. Am I correct in assuming that I can use that to do a build?
Old Sep 17, 2024 | 09:36 PM
440 sixpack's Avatar
440 sixpack
If you're looking for a performance upgrade the place to start is with a 390-rotating assembly. then decide what you want and how much you want to spend rebuilding your 390.
Old Sep 17, 2024 | 10:05 PM
Thewon2141's Avatar
Thewon2141
4th Gear
So basically turn it into a 390 and build it up from there? Will I need to hone out the block to accommodate the pistons?
Last edited by Thewon2141; Sep 17, 2024 at 10:08 PM. Reason: Need to add information
Old Sep 17, 2024 | 11:23 PM
440 sixpack
Your block is the same and so is the bore. same heads. you're going to need new pistons anyway, so a crank and rods are all you need extra.
Old Sep 18, 2024 | 01:00 AM
Thewon2141's Avatar
Thewon2141
4th Gear
Thank you for that it made me do research and I learned about the size of the bore and stroke and how like you said the bore is the same but the stroke is longer. Makes so much more now!! I also learned that I can get it bored out to .030 over to get a bit extra hp but have to bigger pistons.. Any suggestions on crankshafts and rods?
Old Sep 18, 2024 | 09:10 AM
440 sixpack
Most likely you're going to have to bore it anyway.
I used to find good original parts when I did a couple, but now looking on Summit or something probably makes more sense.
Old Sep 18, 2024 | 10:01 AM
Olblack's Avatar
Olblack
I had my 390 bored .30 over and used 10.5 to 1 compression pistons for a little extra oomph. You may also consider headers
Old Sep 18, 2024 | 10:30 AM
flowney's Avatar
flowney
2X on that. Scat, Eagle et.al sell new reciprocating assemblies for the FE. This is a smart move in that the kit you get includes everything you'll need for a short block (rings, bearings, seals, crank and rods) as a balanced set. For a few extra bucks you can up the stroke even further (445 CID) w/o having to modify the block. First get the block clean and up to specs. That could include decking, line boring the mains and cylinder boring (no greater than 0.060"). Check the lifter bores too. Like a house, your engine can only reliably deliver what the foundation will support.
There are also top end kits as well from Edelbrock, Trick Flow et. al. Those will get you to long block status. Using kits with parts that are known/proven to work well together is almost always better than random selections.
Sandbox13
Jan 20, 2024 12:38 PM
Nosekabel_the_fable
Dec 29, 2021 11:56 AM
MessengerII
Mar 11, 2010 06:48 AM
robertskunfused
Dec 8, 2002 11:13 AM
tomridge
Nov 12, 2001 04:06 PM
