Borrowed this picture from the internet but it's Identical to the park brake pedal I'm using that I took out of a 1983-5 F350 .I am missing the switch and can't seem to find one. My search has been for a park brake switch for those years but can't seem to find anything like it.
I've used the same pedal in both my pickup and panel and this one I'm doing now. Both the panel and pickup has the switch but this one only has the bolt that supports the switch. I assume someone removed it before I got it..
Thanks. I'll look into the one on LMC..
Park brake signal lamp switch assy, E4TZ 15A851-B.
Here's an NOS one on ebay. Ad says ended, not sold, so presumably he still has it. It just ended last week. You may also find it elsewhere by searching the number. I didn't spend a lot of time searching. https://www.ebay.ca/itm/235077894214
It's hard to see what is in the bag on that one Wayne.. plus it would likely amount to over $100 by the time I got it here..
