Code 122
Old Sep 17, 2024 | 01:19 PM
FordLady1979's Avatar
FordLady1979
2nd Gear
Code 122
I found out today that you could check codes by the check engine light flashes and it came up with this 122. It’s a 94 f150 5.8.
I’ve had the check engine light on since July. had it checked three times at O’Reilly, but they never could find any codes. Finally Sunday it left me stranded on I 94 and the accelerator stopped working. It will not engage any gear including reverse. Would this sensor cause the tranny to go out? Or is this just symptoms of the bad sensor and housing?
Old Sep 17, 2024 | 03:02 PM
Soup bean's Avatar
Soup bean
Code 122 is for the Throttle Position Sensor. Here's a thread on how to test it https://www.fullsizebronco.com/threa...stment.203080/
I suspect your transmission issue is being caused by the TPS issue, but I'm not one hundred percent sure. I don't know automatic transmissions. I would start with the throttle position sensor testing, and go from there.
Also check the throttle cable visually, where it connects to the throttle body and make sure it's moving the throttle plates properly and the E clip is in place, where the green dot is.
Old Sep 17, 2024 | 03:15 PM
Soup bean's Avatar
Soup bean
What housing are you referring to? Is something physically broken?
Old Sep 19, 2024 | 12:24 PM
FordLady1979
2nd Gear
sorry I think I meant throttle body as a whole?
mastersativa
Aug 8, 2022 01:29 PM
ThaBiggT
Sep 21, 2019 04:28 PM
richdavis69
Dec 29, 2011 04:12 PM
magnet1
2004 - 2008 F150
Dec 17, 2010 02:29 AM
lajeunesserick
Feb 17, 2007 10:11 PM
