Caliper bracket?
Old Sep 16, 2024 | 05:36 PM
DriverD's Avatar
DriverD
Caliper bracket?
1997 E150
I'm replacing the pads on my front brakes. That went pretty well, but one mounting bolt screws in but will not tighten. I guess I need to replace the bracket on that side.
Of course, I can't just take the old one to the parts store to match it with a new one. Searching eBay reveals tons of F150 parts, as usual. Are these parts the same?
Old Sep 17, 2024 | 05:18 AM
JWA's Avatar
JWA
The E-250 brackets would be different from the E-150's.
Find the OEM part number then search eBay for that number.
Old Sep 17, 2024 | 08:18 AM
manicmechanic007's Avatar
manicmechanic007
Those small bolts that hold the caliper, just go into pins that are replaceable, along with the bolts
If it's the bigger bolts that hold the mount to the knuckle, that is a bit worse, you may need a knuckle
It should be pretty easy to find all those parts used, cheap, at a wrecking yard
Buy new might cost some big money,
Yes, Ebay your best bet once you find part numbers
Old Sep 17, 2024 | 05:24 PM
DriverD's Avatar
DriverD
I went ahead and did the other caliper just to be certain that the bolts screw into the bracket.
I found the Ford part number on a Ford parts site. They give the part number as 4C2Z-2B134-AA.
I found that part from a seller on eBay. The description says it fits 02-04 E-150, "but might fit other years."
I'll remove that caliper again to inspect the bracket and see if it looks like the one on eBay.
Mine are single-piston calipers, which I bought from NAPA five years ago.
Old Sep 18, 2024 | 05:16 PM
DriverD's Avatar
DriverD
I took the first caliper off again. There is no bracket on this model. The bolts screw into the steering knuckle. One bolt has some flattened threads, but I was able to screw another bolt into the hole.
I hope that I can just buy new bolts and use Loctite.
ChiefGeek
Jun 26, 2022 06:25 PM
Furniture Doctor
Mar 29, 2014 10:26 PM
Cpljdrose
Apr 22, 2011 07:32 AM
pinto21632
Jun 11, 2009 02:37 PM
mwagner9
Jul 5, 2006 01:14 PM
