Correct rear driveshaft
Old Sep 15, 2024 | 09:53 PM
Perrin307's Avatar
Perrin307
4th Gear
I've found an 84 f250 I'm interested in, but the rear drive shaft is missing. Truck is a single cab long bed, 4x4 straight six with 4spd manual. Axle code is 26 so the Ford rear, not Dana I think. From what I could see, it's supposed to be 53 9/32" long, but the part number for that axle gives no results. E4TZ 4602-D. What are my best options? Also, what rear end does it actually have?
Old Sep 16, 2024 | 07:40 AM
Max Capacity's Avatar
Max Capacity
Check, www.car-part.com the junkyards might be able to find the right shaft.
Another place for info, https://www.garysgaragemahal.com/
Old Sep 16, 2024 | 08:42 AM
FuzzFace2's Avatar
FuzzFace2
IS it a 2 pc or 1 pc drive shaft?
Is the slip yoke at the transfer case or the drive shaft?
Being a 4x4 thinking the slip is in the drive shaft?
When you measured was the truck sitting on all 4 wheels on the ground?
If cant find one in a local junk yard find a local shop that can make one but you will need the info I asked above.
Only thing I did not say was the Ujoint sizes.
You will also need to measure across the yokes that are on the truck and the cup dia.
I know you hate to get a shaft made and it is not your truck but you were going to buy a junk yard one no?
What if it is bent from the fork lift moving the truck around the yard?
I had a little dent in a shaft I needed made shorter and the shop would not use it because if it and I fully understood because of balancing.
Dave ----
Old Sep 16, 2024 | 09:05 AM
Max Capacity
If you need you made, try, thedriveshaftstore.com Call them.
Old Sep 16, 2024 | 06:21 PM
Franklin2's Avatar
Franklin2
Here are all the possible combinations of driveshafts for a 1984 f250. I believe a 8ft is 133" wheelbase but you could check that with a measuring tape. And of course you have 4x4. Your 4 speed will be the T-18.
133" WB, AT, 4x2, 2 piece, front section
155" WB, MT, 4x2, front section, New Process manufactured transmission
133" WB, AT, 4x2, 2 piece, rear section
137" WB Chassis Cab, AT, 1 piece
137" WB Chassis Cab, AT, 2 piece, front section
137" WB Chassis Cab, AT, 2 piece, rear section
155" WB, MT, 4x4, rear section
155" WB, AT, 4x4, front section
133" WB, AT, 4x2, 1 piece, AOD transmission, Ford manufactured axle
133" WB, AT, 4x2, 1 piece, AOD transmission, Spicer manufactured axle
133" WB, AT, 4x2, 1 piece, C6 transmission, Ford manufactured axle
133" WB, AT, 4x2, 1 piece, C6 transmission, Spicer manufactured axle
133" WB, MT, 4x2, 1 piece, Ford manufactured, Ford manufactured axle
133" WB, MT, 4x2, 1 piece, Ford manufactured, Spicer manufactured axle
133" WB, MT, 4x2, 1 piece, New Process manufactured, Ford manufactured axle
133" WB, MT, 4x2, 1 piece, Warner manufactured, Ford manufactured axle
137" WB Chassis Cab, MT, front section, New Process manufactured
137" WB Chassis Cab, MT, front section, Warner manufactured, T-18 transmission
155" WB, AT, 4x2, rear section
133" WB, MT, 4x2, 1 piece, New Process manufactured, Spicer manufactured axle
133" WB, MT, 4x2, 1 piece, Warner manufactured, Spicer manufactured axle
133" WB, MT, 4x2, 2 piece, front section, New Process manufactured
133" WB, MT, 4x2, 2 piece, front section, Warner manufactured, T-18 transmission
155" WB, MT, 4x2, front section, Warner manufactured, T-18 transmission
161" WB Chassis Cab, AT, front section
161" WB Chassis Cab, AT, rear section
161" WB Chassis Cab, MT, front section, New Process manufactured transmission
133" WB, AT, 4x4, flange joint, Ford manufactured axle
133" WB, AT, 4x4, flange joint, Spicer manufactured axle
133" WB, AT, 4x4, slip yoke joint, Ford manufactured axle
133" WB, MT, 4x2, 2 piece, front section, Warner manufactured, T-19 transmission, from 3/84
133" WB, MT, 4x2, 2 piece, front section, Warner manufactured, T-19 transmission, thru 2/84
133" WB, MT, 4x2, 2 piece, rear section, from 8501 GVW, New Process manufactured
133" WB, MT, 4x2, 2 piece, rear section, from 8501 GVW, Warner manufactured, T-18 transmission
133" WB, MT, 4x2, 2 piece, rear section, from 8501 GVW, Warner manufactured, T-19 transmission, from 3/84
133" WB, MT, 4x2, 2 piece, rear section, from 8501 GVW, Warner manufactured, T-19 transmission, thru 2/84
133" WB, MT, 4x2, 2 piece, rear section, thru 8500 GVW, Ford manufactured axle
133" WB, MT, 4x2, 2 piece, rear section, thru 8500 GVW, Spicer manufactured axle
133" WB, MT, 4x4, flange joint, Ford manufactured axle
133" WB, MT, 4x4, flange joint, Spicer manufactured axle
133" WB, MT, 4x4, slip yoke joint, Ford manufactured axle
137" WB Chassis Cab, MT, front section, Warner manufactured, T-19 transmission, from 3/84
137" WB Chassis Cab, MT, front section, Warner manufactured, T-19 transmission, thru 2/84
137" WB Chassis Cab, MT, rear section, New Process manufactured
137" WB Chassis Cab, MT, rear section, Warner manufactured, T-18 transmission
137" WB Chassis Cab, MT, rear section, Warner manufactured, T-19 transmission, from 3/84
137" WB Chassis Cab, MT, rear section, Warner manufactured, T-19 transmission, thru 2/84
155" WB, AT, 4x4, rear section
155" WB, MT, 4x2, rear section, New Process manufactured transmission
155" WB, MT, 4x2, rear section, Warner manufactured, T-18 transmission
155" WB, MT, 4x2, rear section, Warner manufactured, T-19 transmission, from 3/84
155" WB, MT, 4x2, rear section, Warner manufactured, T-19 transmission, thru 2/84
161" WB Chassis Cab, MT, front section, Warner T-19 transmission, from 3/84
161" WB Chassis Cab, MT, front section, Warner T-19 transmission, thru 2/84
161" WB Chassis Cab, MT, rear section, Warner T-19 transmission, from 3/84
161" WB Chassis Cab, MT, rear section, Warner T-19 transmission, thru 2/84
133" WB, AT, 4x4, slip yoke joint, Spicer manufactured axle
133" WB, MT, 4x4, slip yoke joint, Spicer manufactured axle
155" WB, AT, 4x2, front section
155" WB, MT, 4x2, front section, Warner manufactured, T-19 transmission
155" WB, MT, 4x4, front section, New Process manufactured transmission
155" WB, MT, 4x4, front section, Warner manufactured, T-18 transmission
155" WB, MT, 4x4, front section, Warner manufactured, T-19 transmission
161" WB Chassis Cab, MT, rear section, New Process manufactured transmission
Old Sep 16, 2024 | 06:28 PM
Franklin2's Avatar
Franklin2
You can see you have to select whether you have a flange connection to the transfer case or a slip yoke connection. I picked a 33" WB, AT, 4x4, slip yoke, Ford manufactured axle and got about 25 hits around the country. What state do you live?
I then picked 133" WB, MT, 4x4, flange joint, Ford manufactured axle and got about the same amount of hits around the country.
Old Sep 28, 2024 | 05:53 AM
Perrin307's Avatar
Perrin307
4th Gear
Wow, thanks for all the info! Unfortunately (and fortunately) after getting time to look at the truck, none of that applies, as it'd been upgraded to full float dana 60 some time in the past. Bought it, and if the truck doesn't work out, I can sell the offenhauser intake on it for what the truck cost. The diff will likely need to be fully rebuilt however, and that's out of my skill range and budget. so my next question is what other year rear ends fit as a direct swap?
Old Sep 28, 2024 | 07:25 PM
Franklin2's Avatar
Franklin2
I would get a Ford/Sterling full float rearend if I needed a truck to haul heavy loads. If you just need it for regular truck duties, you could get a lighter duty f250 semi-float rearend. They all fit from the f250/350 up to 1998. You just have to make sure you get the correct ratio. There was really only two common ratios for the 4x4 trucks, a 3.55 and a 4.10.
RobertsHj
Jul 22, 2024 09:39 AM
theworstshadetreemechanic
Jun 21, 2022 09:27 PM
DontKnowJackS
Dec 20, 2019 09:12 PM
2002sport
Jan 31, 2006 10:44 PM
nitro94
May 6, 2000 10:56 PM
