Tire pressure?
Old Sep 15, 2024 | 08:08 AM
wpg_250's Avatar
wpg_250
Tire pressure?
I'll be driving 6 hours today to pick up a slide in weighing approximately 2100lbs and wondering if I should set all 4 tires to the max 80psi before I leave or just set the rears to max? I keep fronts at 70psi and rears at 65psi when unloaded and when I haul pallets of flooring around weighing 1600-1800lbs I set the rears to 70psi(cold of course) and that seems to work just fine so curious what you fellas would do? Driving 6 hours unloaded with rears set to 80psi will make for a bumpy ride, but if that's what's best that is what I'll do.
Thanks
Old Sep 15, 2024 | 08:40 AM
Mickey Bitsko's Avatar
Mickey Bitsko
Air up when you get there, adjust if need be on the trip back home.
Enjoy the maiden voyage, don't forget pictures
Old Sep 15, 2024 | 08:57 AM
wpg_250's Avatar
wpg_250
How do I air up to max psi when tires are hot?
Old Sep 15, 2024 | 09:01 AM
Pelican3's Avatar
Pelican3
I note the air pressure cold and say I need to add 10 psi. When I get to the air pump, just add 10 psi, no matter what your starting pressure is.
Old Sep 15, 2024 | 01:14 PM
bigwin56f100's Avatar
bigwin56f100
I run max cold settings always
Old Sep 15, 2024 | 01:23 PM
wpg_250's Avatar
wpg_250
You must have some smooth a$$ roads where you live then lol.
Old Sep 15, 2024 | 10:51 PM
SteveSBD's Avatar
SteveSBD
I run 55 all around when empty, and 80-rear 60-front when the camper is on. I would just air up before you leave. One bouncy leg of the trip isn't going to kill you.
Old Sep 15, 2024 | 10:53 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
I'd air them up while they're cold. Yes a little more bumpy, but not that much more. Then you don't have to fiddle with it when you arrive.
Old Sep 16, 2024 | 06:49 PM
bigwin56f100
oh it rides horribly since I'm aired up and I have the lower Torklift stable loads engaged. But most of the time the camper is loaded and or a trailer is in tow. I definitely like riding in a "truck"
westay34
Jul 19, 2012 11:26 PM
wolffee
Mar 12, 2012 07:24 PM
Y2KPSD
6.7L Power Stroke Diesel
Dec 20, 2010 10:26 PM
crosbo
Jun 27, 2009 01:07 AM
DieselRunner
16
Feb 15, 2008 09:51 PM
