horn pad question
Old Sep 14, 2024 | 01:38 PM
tbruz's Avatar
tbruz
horn pad question
1975 F250 highboy with the woodgrain horn pad.
Curious if anyone knows if the aftermarket horn pads (black or woodgrain) can have their cover removed to be replaced with my patina woodgrain horn pad?
My pad is perfect but the underlying support structure is broken up. The pad "ends" always catch on my palms on aggressive turns and pull the pad up out of the steering wheel.
My notional plan is to purchase an aftermarket pad assembly and swap out my patinaed pad onto the new aftermarket sub-structure.
Thanks in advance.
Tbruz
Old Sep 17, 2024 | 01:45 PM
tbruz's Avatar
tbruz
No input from the collective brain trust?
I guess its almost a moot point as all the vendors appear to not have the horn pads in stock...
Would still like to know if this idea would work though.
Thanks
Tbruz
Old Sep 17, 2024 | 04:03 PM
5851a's Avatar
5851a
Can you find a salvage yard? An old one that's overgrown so as to keep the old dents in the shade.
Old Sep 17, 2024 | 04:24 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
So on a 75 you have the smaller style right, where the horn pad fits inside the center of the steering wheel....yes? And you need just the piece that is below the rubber outer piece right? I bet to get just that inner piece you will have to buy a complete repop horn pad. Unless I have a good one in my parts shed.
Old Sep 17, 2024 | 06:05 PM
tbruz's Avatar
tbruz
Rich, your description is accurate.
Appreciate if you can check your parts stash as all junkyards around me have long since purged any vehicle from pre 2010.
I'd be willing to buy the whole repop pad from any vendor IF
1- I get confirmation that I can remove the rubber cover and replace it with my patina one
2- any vendor had stock
Thanks
Tbruz
Old Sep 17, 2024 | 06:21 PM
77&79F250's Avatar
77&79F250
Well look what I found sitting in my parts stash and yes the rubber cover comes off.
Old Sep 17, 2024 | 06:43 PM
tbruz's Avatar
tbruz
Rich,
If the plastic under the cover is not all brittle and broken up(especially the ends) shoot me a price.
Thanks
T
Old Sep 17, 2024 | 08:50 PM
77&79F250's Avatar
77&79F250
It looks good from the back side, no cracks or feeling of cracked ends. Do you want me to dig a little deeper and take the outer rubber cover off? I got it as a back up for my 77 so it is in reusable condition to me.
Old Sep 17, 2024 | 09:56 PM
tbruz's Avatar
tbruz
Sure, peel back both the ends; that's where mine has deteriorated.
Tbruz
Old Sep 17, 2024 | 09:59 PM
77&79F250's Avatar
77&79F250
I will peel it back tomorrow and let you know.
Old Sep 19, 2024 | 06:19 PM
77&79F250's Avatar
77&79F250
Comes off easy peasy. By hand roll the lip and un hook the 4 little rubber buttons near the middle/center. Use needls nose if you are scared. Lol Then lift it up and change the fold angle of the rubber part, to be opposite of the hard plastic angle. Then just slide it off the ends, one at a time. Reinstalled in reverse order. Look Ma, no cracks. Pm sent.
custom1106
WTB - Parts & other
Jun 14, 2011 01:10 AM
Cowboy34
Feb 10, 2007 03:53 PM
SpankF100
Jan 16, 2005 06:49 AM
gavin_smith_1999
Aftermarket Products
Nov 18, 2002 06:22 PM
