Hydra Chip Performance (disappointed) RESOLVED
Old Sep 14, 2024 | 06:17 PM
01__Excursion's Avatar
01__Excursion
Is your hydra chip properly seated in the PCM slot opening, and all the traces are clean and making contact?
Remember to always have the key out of the ignition when fiddling with the Hydra chip connection. Or better yet, disconnect the battery too.
Old Sep 14, 2024 | 06:48 PM
Bronccat's Avatar
Bronccat
I cleaned the silicone from the contacts and valleys with the wood handle. Certainly worth another look. But would it have shut the truck down in NS if there wasn't good connectivity?
Thanks
Old Sep 14, 2024 | 06:50 PM
Bronccat's Avatar
Bronccat
Originally Posted by John in OkieLand
I don't think you will see much of a Difference between 100hp and 80hp...
been a couple years ago, but I remember testing the different settings, and it would hit 80 mph pretty quick.
my Edge CTS-3 has a monitor setting that I ought try out,
it will Log and let you save to an SDcard, the results of speed tests like that.
but, a SWAG, is that from 10-15 mph to 80 happens pretty fast with the 80hp tune.
No where around my home where I can try that w/o attracting unwanted attention.
Wish I had seen your post this morning, I went to town and back, and there are several straight line places on the US-hwy where I could have tried that out....
I know it will hit 100mph if I don't get off the throttle.
Thanks. I tried 80 and 100 only for the sake of sample size. No difference from stock for sure.
I'm fortunate to have an industrial park with a straight away nearby 😁
Old Sep 14, 2024 | 07:36 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Something to also keep in mind: Tunes take time to settle in. It takes 1-2 tanks of fuel for the PCM to adjust the fueling tables and shift strategy for the power. You'd need to run the 80HP tune for 2 tanks of fuel before anything.
Old Sep 14, 2024 | 08:21 PM
John in OkieLand's Avatar
John in OkieLand
I know you said you cleaned the contacts with the wood handle,
but you did not use the Scotch Brite??
those contacts need to be squeaky clean, w/o taking off any of the gold contact layer.
and, seal it up with Duct Tape, and the Zip tie they included....
you do NOT want that Chipset to slide off of the PCM while driving, you will say goodbye to a good PCM if that happens.
Old Sep 14, 2024 | 08:38 PM
Bronccat's Avatar
Bronccat
I did not know this at all. Thank you.
Old Sep 14, 2024 | 08:40 PM
Bronccat's Avatar
Bronccat
Yes. Wood handle, brass brush then scotch Brite. And it's taped in place.
I'll definitely pull it tomorrow and recheck the contacts, etc.
Old Sep 14, 2024 | 08:49 PM
John in OkieLand
ummmmm,
mine did not.
well,
that might be,
my Hydra has been on the truck 2 years now.
but I noted the improved shifting immediately when I tried it.
it took effect instantly.
Old Sep 15, 2024 | 06:15 AM
01__Excursion
If you're confident they're clean, then probably best to leave alone, rather than disturb again.
And you're sure you downloaded the standard canned tunes that are NOT for a modified valve body transmission?
Old Sep 15, 2024 | 12:06 PM
Bronccat's Avatar
Bronccat
UPDATE - RESOLVED
So, as I said I had used the wood handle, wire brush and scotchbrite pad.
After comments above, I decided to pull it again and clean with alcohol, SB pad then alcohol again. You couldn't feel or see any silicone but that did the trick!
Thing runs like a scalded dog now. Thanks all!
Old Sep 15, 2024 | 01:07 PM
John in OkieLand
I have worked as an Electronics Tech since 1958.
poor Connections have always been a PITA to Diagnose.
if you are not sure, clean them thoroughly ( as you did ) and start from Scratch.
glad I looked just now, I was going to fire up the Excursion to go to town, at 12 mpg, that would be costly for me.
we have two cars that get 25mpg all the time.
Old Sep 15, 2024 | 05:43 PM
Toreador_Diesel
ummmmm,
mine did not.
well,
that might be,
The shifting is almost instantaneous however, the fueling takes time to settle in. It takes longer on the 6.0 trucks but there's a relearn that can speed things up.
Old Sep 22, 2024 | 03:23 PM
  #28
timf150's Avatar
timf150
I had the same issue. I though I had it all cleaned up properly but I guess not. I pulled it again and did a more detailed cleaning with the brass brush and scotch pad and.......Yes, I can now tell the difference. Very nice and what I was looking for with it.
FTE is the best.
Tim M
Old Sep 28, 2024 | 09:18 AM
  #29
ScaldedDog's Avatar
ScaldedDog
HEY!! That's my line!!
Glad you got it figured out.
Mark
Old Sep 28, 2024 | 09:29 AM
  #30
Bronccat's Avatar
Bronccat
Mark
Thanks man
Auditor2020
May 21, 2021 10:00 AM
MDH16
Computer Chips & Tuners
Jun 28, 2018 01:13 PM
Hiflyer746
Nov 4, 2006 08:55 AM
pastormiketkd
Aug 11, 2005 05:09 PM
chadrock
Apr 13, 2001 02:20 PM
