Gluing felt window tracks....
Old Sep 10, 2024 | 08:13 AM
clintonvillian's Avatar
clintonvillian
How much adhesive is needed to hold the tracks in place?
I am not using any clips. They seem to stick pretty snug into the door, just a few dabs? Or should I really coat the metal tracks?
Old Sep 10, 2024 | 05:49 PM
Bluey Zedoff's Avatar
Bluey Zedoff
I used a bead of Sikaflex...and gloves.
Old Sep 10, 2024 | 08:57 PM
blake in spokane's Avatar
blake in spokane
Is there a Sikaflex part # ?
Old Sep 11, 2024 | 05:48 AM
CharlieLed's Avatar
CharlieLed
The original MidFifty kits had small hardwood blocks that were used in place of the OEM metal tabs. The procedure was to glue the blocks in place and then use a small flathead screw to hole the felt to the block. Once installed, the screw head pulls into the felt and does not interfere with the window glass.
Old Sep 11, 2024 | 08:13 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
I glued mine in but I didn't use much. I know it's not much help but gluing was much easier than trying to seat those little clips. I'm pretty sure I used black weather strip adhesive (aka in yellow known as monkey snot).
J2H
17
Jul 7, 2024 07:48 PM
Squanto
Oct 6, 2023 03:22 PM
silar
Jul 27, 2015 11:21 AM
timellis
Aerostar
Dec 20, 2010 07:21 PM
Diesel_Brad
Aug 23, 2009 09:04 PM
