Engine swap
Old Sep 28, 2024 | 11:16 AM
  #46
Colton horn's Avatar
Colton horn
Leak
Where could this be coming from I believe its coolant.... its not.fuel for sure or oil....
Old Sep 28, 2024 | 11:40 AM
  #47
Pikachu's Avatar
Pikachu
It could be the oil cooler mount to engine block gasket or the block heater where it threads into the oil cooler mount above the oil filter. Hard to tell from the video.
Old Sep 28, 2024 | 12:08 PM
  #48
udsuth78's Avatar
udsuth78
Yeah the oil filter housing is also half of the oil cooler assembly. You might try snugging the bolts to the block just a little, and I mean just a little. Don't want to risk breaking anything now.
Old Sep 29, 2024 | 08:09 PM
  #49
RA101725's Avatar
RA101725
Banned
Mileage on the other engine and what do we suspect happened to it? You don’t think it was just oil cooler seals that failed possibly? Was there oil in the coolant also?
Old Oct 11, 2024 | 04:52 PM
  #50
Colton horn
mileage is unknown and yes on the original engine I took out there was a oily filmy coating inside the coolant reservoir .... do another question why would I get a crank no start if I tighten the sheetmetal nut on the ipr valve but loosen it a tad and it will run until it gets way loose then will run crappy til it falls off or I tighten it back up......
Old Oct 11, 2024 | 05:56 PM
  #51
RA101725's Avatar
RA101725
Banned
That’s a good question. Even just finger tightening it will usually “fix” a no start because of it. I don’t think they have to be much tighter than an easy cinch past finger tight. It might just be a bad part.
Old Oct 12, 2024 | 03:01 AM
  #52
udsuth78's Avatar
udsuth78
Sounds like it's bad or heading that way at least. How tight you get the tin nut really shouldn't have any effect. The only reason it's recommended to only go 1/4 past hand tight is for the sake of the but not the coil. Is it an OEM part? The fakes and knockoffs are another story though. Those things have been known to do some weird crap right out of the box. BTW a Motorcraft IPR won't come in a box. It will be in a foil pouch in a plastic bag and cost you your first born or reproductive organ of your choosing.
buickbuggy
6.4L Power Stroke Diesel
16
May 15, 2020 12:01 PM
rodolan
Dec 16, 2009 10:04 PM
shift6durastroke
Dec 6, 2009 08:23 PM
Browning
Sep 16, 2007 10:16 PM
oldgoat50
Nov 10, 2006 01:25 PM
