1996 bronco transmission issues
like clockwork everyday after i have started and driven perfectly a few times on startup my transmission will not want to shift out of 1st gear. I can manually put into 2nd drive awhile and then shift into od and everything works as it should…. I’ve replaced speed sensor and neutral safety switch…. Any help would be appreciated!
2 wheel drive filter fell into the bottom of the 4 wheel drive pan?
Check the trans for codes, it shifts electronically
There can become an open in the trans harness to the solenoids
