1998 Expedition Shuts Down
Old Sep 2, 2024 | 07:52 PM
ghhubbell's Avatar
ghhubbell
6th Gear
My son and I have the same year 5.4 expedition and the same problem. When in low going downhill slowly, if I stop the engine sometimes dies. I notice the RPM's drop under the idle RPM when this happens. I checked with him and he has had the same problem. Rig starts right up and no check engine light. I never had this problem while hunting last year but had it happen about 5 times this month while hunting in the same area. One time I had the transmission in 2nd and when I came to a slow stop the engine died. I am not driving in 4wd. Can anybody give us an idea why this happens? Thanks.
Old Sep 3, 2024 | 07:11 AM
alloro's Avatar
alloro
I would focus on the idle air control valve (IAC). When your foot is off the gas pedal this valve control idle speed. If it gets worn or dirty it can get sticky and not respond as it should. Often if you remove it, you can spray carb cleaner in the mechanism and get it to work again, otherwise, just replace it.
Old Sep 3, 2024 | 09:52 AM
ghhubbell's Avatar
ghhubbell
6th Gear
Thank you, I'll look into that. Dusty as one could imagine on dry hot dirt roads so this could be the issue.
Old Sep 3, 2024 | 10:28 AM
ghhubbell's Avatar
ghhubbell
6th Gear
This problem only occurs when the car is downhill so I am not so sure the ACV would be the problem.
pray for surf
13
Jan 21, 2022 04:49 PM
Donna Bowman Leever
Jan 15, 2018 06:57 PM
wondrn
Jul 22, 2014 06:40 AM
DIV16
Nov 25, 2002 09:37 AM
supercomp2
Mar 22, 2001 12:19 PM
