Injection pump
Old Sep 2, 2024 | 06:19 PM
94powerstroke's Avatar
94powerstroke
Injection pump
Hi guys I’m thinkinking about changing the injection pump on my 2012 I’m undecided over doing a duct conversion vs spx pump anyone have experience both? If a dcr grenades does it trash the fuel system?
Old Sep 2, 2024 | 06:46 PM
Overkill2's Avatar
Overkill2
Water won't grenade a DCR. S&S posted a video where a test truck was getting bad fuel, on a regular basis, enough to cause rust in the aftermarket fuel filter system's metal filter cans and the DCR kept chugging along.
As to "duct conversion," do you mean a disaster prevention kit? All up to you on what you want to do, but at the least install a S&S Gen 2.1 kit to protect the rest of the fuel system if the CP4 goes or go for it all, more $$, and install a DCR. My 2 cents worth.
Old Sep 2, 2024 | 07:01 PM
94powerstroke
No duct dcr damn spell checker
Old Sep 3, 2024 | 07:27 AM
rufushusky's Avatar
rufushusky
The DCR is designed to resemble the CP3 more than the CP4, the CPX is, which is what I am inferring the "SPX" above is, is a modified CP4. Same cam and lobe design, albeit with pinned buckets and a bifurcated fuel feed. A 2020+ pump and DPK is effectively the same thing. Given the choice between the two, DCR all the way. Initial response seems to be positive on the DCR. Only issue I have seen to date is a busted inbound fuel line, which isn't a problem of the pump itself.
Time will tell how good the DCR ends up being, however it is off to a very good start thus far.
Old Sep 3, 2024 | 08:03 AM
JoeUser's Avatar
JoeUser
If I'm not mistaken, their Gen 2 kit has resolved any hose issues. I mentioned my concerns about this very issue to the shop that's going to install mine in two weeks, and they confirmed that the newer generation kit addressed that Gen 1 issue (and, since they're an S&S distributor they no longer stock nor install Gen 1 kits).
Old Sep 3, 2024 | 08:24 AM
rufushusky's Avatar
rufushusky
Given how Johnny on the spot S&S has been, doesn't shock me they tackled it so quickly.
Old Sep 3, 2024 | 12:47 PM
Overkill2's Avatar
Overkill2
I wonder how many miles their test mule trucks had in total with the early DCR pumps before they put it out for sale.... I bet you thousands....
anyways, check this out...
Old Sep 5, 2024 | 02:35 PM
senix's Avatar
senix
DCR all the way. Mine has been flawless.
Old Sep 5, 2024 | 02:45 PM
JoeUser's Avatar
JoeUser
Roger that. Two more weeks, and that CP4 'sword of Damocles' will no longer be hanging over my head. Also means that I can cut back on the fuel additives, and run the occasional Meaner Kleaner for injector and line maintenance.
Welk49
Feb 27, 2010 01:17 PM
bigbadwolfe
Apr 1, 2008 08:27 PM
dennis11
Feb 17, 2008 10:25 PM
