rear a/c lines
Old Aug 27, 2024 | 12:13 AM
hanoverclarkegs's Avatar
hanoverclarkegs
rear a/c lines
Does anyone know what the part numbers are for the 2 short a/c lines in the rear between the under body a/c lines and the TVX inside the jack compartment? I'm in need of the high pressure one.
Old Aug 27, 2024 | 05:27 AM
01__Excursion's Avatar
01__Excursion
All appear to be discontinued. And it's tough to get a correct image.
https://parts.lakelandford.com/p/For...3Z19835AB.html
There are 2 callout numbers for those tubes, which return 8 part numbers with footnotes of descriptions.
Both lists are in order, first callout description is the first part number in the last list
Old Aug 27, 2024 | 10:23 AM
hanoverclarkegs
Perfect, thanks.
Old Aug 27, 2024 | 10:57 AM
Antonm23's Avatar
Antonm23
If the hoses you need have been discontinued by Ford and are not longer available, you can just make your own. They're just hoses, it's not like hoses are complicated tech.
When I was engine swapping my Excursion I needed to make custom AC lines, bought the needed hoses and fittings from ColdHose.com (link below) and the crimp tool off Amazon (Cold Hose sells the crimp tool as well, but the Amazon knockoff was way cheaper). Not a hard or expensive process really, my custom hoses came out cheaper than it would've buying a new set of replacement stock hoses.
Cold Hose website
https://coldhose.com/?utm_source=goo...SAAEgLmSfD_BwE
Amazon AC line crimp tool (this may not be the exact one I have, but they are all similar and probably come for the same Chinese factory)
Amazon Amazon
If for whatever reason you just don't want to make your own, then most hydraulic shops can make AC lines too. Just be prepared to PAY for their services. I got a quotes from a couple local hydraulic places to make my AC lines, but after seeing the price on the quotes, I went out and bought the materials & tool to make them myself.
rothrojc
May 26, 2022 08:37 PM
dvldog458
Sep 20, 2019 09:57 AM
vettman
Aug 21, 2006 03:53 PM
deisele75
Feb 18, 2005 11:50 PM
