Brake lines
Old Aug 19, 2006 | 06:04 PM
vettman's Avatar
vettman
Brake lines
Need to replace rear brake lines (left and right lines from fitting at top of the rear diff.) on 91 Explorer 4WD, 4L. Is there a source for pre-bent steel lines, or will I have to have to bend some replacements? Thanks in advance for any and all replys.
Old Aug 19, 2006 | 06:40 PM
aquanaut20's Avatar
aquanaut20
napa used to carry preformed, but the generic ones are just as easy to install and cheaper, spend a cpLe of bucks and get a bending tool so you don't crimp a bend.
Old Aug 19, 2006 | 06:54 PM
vettman's Avatar
vettman
I'll check NAPA
I have the bending tool--made up some lines for an old Chrysler Newport about 20 years ago. I'll give the local NAPA dealer a call on Monday.
Old Aug 19, 2006 | 07:03 PM
aquanaut20's Avatar
aquanaut20
make sure you use a proper wrench on the fittings and back bleed the lines if possible. alternatly let them gravity feed.
Old Aug 21, 2006 | 06:05 AM
marragtop's Avatar
marragtop
You also should be soaking the bleeder screws on each rear wheel since you will have to bleed the rear cyclinders. Try using PB Blaster.
Old Aug 21, 2006 | 06:17 AM
vettman's Avatar
vettman
Yep--I've been doing that for a couple of days, so hopefully the bleed screws will "cooperate".
Old Aug 21, 2006 | 03:53 PM
vettman's Avatar
vettman
Does anyone know the diameter of the rear brake lines. I hate to take it off and then have to run over to the parts store. Would prefer to purchase in advance of removal. No one has pre-bent lines, and no one can tell me what diameter I need, without looking at the old line.
