7.3L / 6.8L V8 Gasoline Engines Discuss the new 7.3 and 6.8L Gasoline V8s
Ford 7.3 Gas Engine Failure
Old Aug 26, 2024 | 12:43 PM
FilipN's Avatar
FilipN
3rd Gear
I just want to share my experience with the 7.3 gas engine. I’ve got three 2022 Ford trucks with the 7.3 gas engine. Oil changes done every 5,000 miles using AMSOIL top of the line oil.
Truck 1: Engine failure at 94,000 miles
Truck 2: Engine failure at 79,000 miles
Truck 3: So far no problems yet.
I would personally not buy another Ford truck with the 7.3 gas engine. It’s been a total nightmare. Hope this helps you guys make the proper decision.
Old Aug 26, 2024 | 12:51 PM
mat-it's Avatar
mat-it
What was the cause of the engine failures and what was the solution provided by Ford?
Old Aug 26, 2024 | 01:19 PM
FilipN's Avatar
FilipN
3rd Gear
Unknown. They tore the engine open and were unable to find the cause in both of the engine.
They replaced the engines under warranty.
Old Aug 26, 2024 | 10:30 PM
SDDL-UP's Avatar
SDDL-UP
Tiny Chevrolet size lifters?
I understand using parts because they are common, but....
Coyote in an F150 will most likely be my next truck.
Old Aug 27, 2024 | 08:46 AM
DaveMcLain's Avatar
DaveMcLain
What failed in the engine? Camshaft? Roller lifter? Or something else?
Old Aug 27, 2024 | 09:46 AM
1Butcher's Avatar
1Butcher
You just don't bring in the truck and they replace the engine. What was the complaint? Noises? Oil consumption?
There is something missing with this.
Old Aug 27, 2024 | 10:19 AM
85e150's Avatar
85e150
Thread moved to the 7.3 forum.
"...unable to find the cause..."???
If they replaced them under warranty they probably didn't do much of a teardown once it became clear it was a replacement Jon.
Swapped out under warranty? A pita for you with down time, but who doesn't like a new motor?
Old Aug 27, 2024 | 10:28 AM
FilipN's Avatar
FilipN
3rd Gear
On both of the trucks they were unable to find the cause of the engine failure after teardown. Both trucks started to make knocking noises.
Old Aug 27, 2024 | 10:56 AM
SDDL-UP's Avatar
SDDL-UP
That kills me! "Knocking sound", don't know why so replace engine, teardown and still don't know why. I hope they sent both engines to Ford for evaluation!
Old Aug 27, 2024 | 11:54 AM
scraprat's Avatar
scraprat
Top Answer: 5
Would be interesting to know what actually was torn down to find nothing. Oil sample...any glitter?
I'm with 85e150 that it was warranty work with minimal time spent for proper diagnoses/ troubleshooting.
Old Aug 27, 2024 | 12:02 PM
1Butcher's Avatar
1Butcher
When I did warranty work, if there was metal flakes anywhere [trans, engine, diff, etc] it was a complete replacement. Gone are the days where there are mechanics that tear down and fix things. Better to replace the entire assembly vs the hassles of the repair and the potential of the comeback [along with finger pointing on who is at fault]. It is in the interest of customer satisfaction that assemblies get replaced.
At least, that was my experience.
Just because you changed the oil regularly does not mean something might have broken.
Old Aug 27, 2024 | 12:24 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
How long before engine replacement did you start hearing knocking noises? Was there any ticking? did they cut open an oil filter?
Old Aug 27, 2024 | 12:31 PM
Ford8502's Avatar
Ford8502
What models were these trucks and how were they used?
Old Aug 27, 2024 | 01:26 PM
jcb804's Avatar
jcb804
Thanks for sharing even though its not good news. Ive got four 7.3L right now and one is already on its 2nd engine. Purchased an early 2021 and got a little over 30k on it before it went down. That truck has around 50k on the replacement engine now. Other three trucks are 2024 and barely have 20k on them yet.
Waited a few years before we bought the other three hoping Ford worked out the issues. What models are yours and what are the idle hours?
Old Aug 27, 2024 | 08:27 PM
OBS460's Avatar
OBS460
Replaced under warranty at 94k and 79k miles? So you have an extended warranty? This doesn't really help. What model, what do these trucks live their life doing? Are these driven by the same guy everyday or are they slip seat miles?
Pretty vague first post.
