@kry226 Well, for one thing, they probably don't have many miles on them yet.
I'm wondering about this OP post. Warranty at 90K+?
Seems a bit odd, unless he has an extended warranty. Having said that there have been some reports of failures right under 100k miles. Don't know of any failures over 100k miles.
Having three trucks im going to say its safe to assume they are in business. Getting an extended warranty included in the total purchase price gives one more to depreciate and the peace of mind of a warranty for the projected service life of the truck. Its very common for those of us in business.
Besides the Ecoboost V6's the 5.0 Coyote engines have had faulty intake valves also but I have not heard of any being recalled. From what I've seen the don't break they just wear the face of the valve down to a razor sharp edge and start getting low cylinders and misfires.
This thread is about the 7.3. Do they suffer from a valve failure problem?
They have cam/lifter failure issues which is probably what took this man’s 3 engines out. It is probably just another example of an auto manufacturer knowing they have an issue that is safety related and hoping they can avoid the NHTSA and a recall like the above.
it's been over a week since the OP's 3rd post of all time. All of which were in this thread. Always a reliable source when they post n' ghost.
Let me break the crayons out for ya. Ford has a history of calling problems normal for long periods of time (3.5 cam phasers) only to later admit they are real problems. The same with ignoring problems until the NHTSA is involved like 2.7/3.0 recall post. The 7.3 cam/lifter are analogous. It’s a problem. Ford is ignoring it, because the government isn’t on their azz over it, yet. The keyboard commandos with their egos wrapped up in their trucks will always downplay the issues until the companies are forced to admit there is a problem. That’s what I see here. It’s been a week since he posted. He must be troll. 🙄
Let me melt the crayons and spread them over some toast for you. This wouldn't be the first post n ghost with zero evidence posted. That is no different than 3rd or 4gh hand information. It isnt verifiable. I personally know 3 people with F250/F350s and 7.3s that have more miles than mine and they haven't had any engine issues. Every manufacturer ignores problems until they blow up in their face not just Ford. It almost always takes a lawsuit to get any traction from a manufacturer and if you are going to sue you better have REAL evidence of WIDESPREAD failures or you will look stupid showing up to court with copies of these post n ghost threads.
Good luck chicken little. I dont give it a second thought when I drive my truck because I've seen very little real world evidence of an issue. They exist but seem rare not the norm.
It would be interesting to see some pictures of the failed parts but from what I've seen elsewhere on line the roller bearing on the lifter fails and then it eats up the camshaft. GM seems to have the same problem on the LS style engines for some reason which is weird because they seldom had trouble on the Vortec 305's and 350's and they use the same lifters.
Cam profiles are extremely mild on both of those engine types so it would be fun to plot the cam from a 7.3 Ford but I'd bet that it is similar. Ford had very little lifter trouble in the 5.0 and 5.8 engines either. I just wonder if it is just simply poor quality parts from formerly good suppliers. They are inconsistent so if you just happen to get 16 good ones then your engine lasts for a very very long time. It only takes one bad one.
I just wonder if it is just simply poor quality parts from formerly good suppliers. .
My guess is this,
dodge was having 5.7 issues also
Ive got a 2/2020 build truck...p.o had excessive idle hours. Its over 600 idle hours at 46k
I'm thinking about proactively replacing lifters myself when 60k/5yr warranty runs out in few months. Guessing it would be easy to pull apart just like Gm's LS.
Is there a known replacement or upgrade out there? Does this in fact use the same LS lifter?
Johnson Lifters If youre that worried about it. But the heads have to come off.
The 7.3 is not a mild cam profile it is a fast ramp cam with about .600 lift and DEVCT.
Based on comp cams "stage 1" mild cam grind, i would say factory is not super aggressive, but has a ramp rate that flat tappets would not be happy with
Engine Family 7.3L Godzilla RPM Operating Range 1500-6300 Cam Type Hydraulic Roller Camshaft Series Godzilla
Advertised Intake Duration 275°
Advertised Exhaust Duration 288
° Intake Duration at .050 Inch Lift 217°
Exhaust Duration at .050 Inch Lift 229°
Intake Valve Lift 0.598in
Exhaust Valve Lift 0.605in
Lobe Lift Intake 0.332in
Lobe Lift Exhaust 0.336in
Lobe Separation 121°
Intake Centerline 105°
Exhaust Close ATDC 23°
Intake Open BTDC 3°
Exhaust Open BBDC 72°
Intake Close ABDC 34°
Maximum Advance At Camshaft 16 deg https://www.compcams.com/godzilla-st...ic-roller.html
