7.3L / 6.8L V8 Gasoline Engines Discuss the new 7.3 and 6.8L Gasoline V8s
Ford 7.3 Gas Engine Failure
Old Sep 6, 2024 | 01:38 PM
  #31
DaveMcLain's Avatar
DaveMcLain
What you have to remember is that roller cams have different limitations than flat tappet cams do. Flat tappet cams are velocity per degree limited based on their diameter, get too much lift per degree, run off the edge and then the lifter digs into the lobe. Any roller follower camshaft is acceleration limited. It can only increase or decrease the speed of the valvetrain per degree so quickly before the pressure angle on the wheel becomes too high and this either greatly reduces the life of the lifter or snaps the roller right off of the bottom.
It is possible for the stock cam to have accelerations that are pretty darn high and you never know until you plot it but as an example.
I just looked and it has a 1.8 rocker arm ratio so .539 takes a .300 lobe. A stock Chevy LT1 hydraulic roller lobe is 201 @ .050 with a .299 lobe lift.
Old Sep 6, 2024 | 06:40 PM
  #32
OBS460's Avatar
OBS460
Ford uses variable cam timing that can ramp the cam timing instantaneously.
Old Sep 7, 2024 | 12:51 AM
  #33
DaveMcLain's Avatar
DaveMcLain
Originally Posted by #1 Stunna
The GM and Stellantis lifter failures are the result of cylinder deactivation mechanisms which repeatedly activate and deactivate the lifters. Ford is not using cylinder deactivation in the 7.3.
I reground a cam for a customer a month or two ago from one of those 6.2 engines that can deactivate 1/2 of the cylinders and the lobe I repaired was one that has the normal lifter that doesn't shut off.
Old Sep 7, 2024 | 12:55 AM
  #34
DaveMcLain's Avatar
DaveMcLain
I have seen no mention of failed lifter roller bearings at all. All details I have seen are failures at the cam and lifter interface indicating a surface hardness/depth of hardness issue of one or both components or a lubrication issue.
What's weird about that is on previous Ford engines with roller cams the cam cores have been excellent quality but these certainly could be lower quality. Another thing that can cause lobe failures is crankcase moisture. I think that's what cases the lobe damage on the Honda V6 cams. It always happens toward the front of the cam on the front head. That is right where the PCV valve is located.
Old Sep 7, 2024 | 09:21 AM
  #35
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
I know ford big block cam cores have been in short supply most of the year. Crower said they are all supplied from overseas now and the supplier runs the show.
i ended up regrinding a factory core because none of the suppliers could get one. Wouldnt be surprised if we lost some more suppliers in the cam world as a result of the flu hoax along with a dip in material quality.
id really love to know of 7.3 failures with build dates prior to march 2020
Old Sep 7, 2024 | 10:08 AM
  #36
OBS460's Avatar
OBS460
GM and Stellantis use VVT as well.
and it was already stated that GM and Steallantis also had lifter issues. Correlations doesn't equal causation but similar issues and we never had these issues with older pushrod engines running roller lifters.
Old Sep 7, 2024 | 10:51 AM
  #37
KubotaOrange76
rare with flat tappet until last 10-15 yrs
Old Sep 7, 2024 | 03:10 PM
  #38
DaveMcLain's Avatar
DaveMcLain
CWC Textron(large supplier for OEM and aftermarket camshafts and camshaft cores) isn't going to make cast iron camshaft cores for the foreseeable future so this is making new flat tappet cams hard to get. I don't know what cores Estas from Turkey has to offer but in the future they might be the only choice for cast cores besides regrinds.
Maybe what happened at Ford was that all of the people who got the materials and heat treat figured out so good on the roller cams for the older engines retired.
Old Sep 7, 2024 | 07:58 PM
  #39
FishOnOne's Avatar
FishOnOne
And when you think about it, how is this any different than valves failing in the 2.7 and 3.0? Losing motive power is a very common reason stated on the NHTSA for recalls. Why isn’t this a full blown recall?
Because when a valve failure occurs it pretty much puts you on the side of the road immediately whereas a cam lifter failure wont.
Old Sep 7, 2024 | 08:01 PM
  #40
FishOnOne's Avatar
FishOnOne
I wouldn't be surprised if the lifters or cams are made in China just like the cast aluminum rims on these trucks.
Old Sep 8, 2024 | 09:32 AM
  #41
DaveMcLain's Avatar
DaveMcLain
No sir. This is not necessarily always true. Some have had instant no mo go. The lifter rotated, seized, and bent a push rod.
So from what you're saying the system that keeps the lifter aligned with the lobe is what fails and causes the lifter to destroy the cam? What do they use something that's metal or plastic?
Old Sep 8, 2024 | 11:10 AM
  #42
DaveMcLain's Avatar
DaveMcLain
Nothing like having plastic parts in or on an engine.
Old Sep 8, 2024 | 12:43 PM
  #43
OBS460's Avatar
OBS460
I am not sure that is the root cause, but I have read of failures that did exactly this in the 7.3L. There could have been some other failure that precipitated the rotation, like a badly worn/uneven interface between the cam and roller. From what I have read they are made of some type of plastic.
Edit: Found one.
https://www.fordtremor.com/threads/7...g-issue.15992/
There is a lot of speculation and 3rd hand information in that thread.
Old Sep 8, 2024 | 03:30 PM
  #44
Rabert's Avatar
Rabert
4wd Low
Read thru this thread;
7.3 Failures
"https://www.ford-trucks.com/forums/1749008-7-3l-engine-failure-rough-idle-low-compression-lifter-taps.html'
A few of us that have had engine replacements posted their work receipt from the dealership..........
Old Sep 8, 2024 | 04:00 PM
  #45
scraprat's Avatar
scraprat
Top Answer: 5
Talking to OBS460 is like talking to a fence pole. He doesn’t want to hear what he doesn’t want to hear. No amount of documented failures will ever get him to say anything other than live in fear chicken little, blah, blah, blah. Fortunately, most people who are actually open minded will just write him off.
You're new hear and have so much to teach us. We've been stumbling around in the dark hoping for a educational tutorial. It's not like this subject hasn't been brought up before already.
Some of us realize that there are bad parts out there and maybe even bad design....they are designed and made by man after all.
You can pound your chest and point fingers at manufacturer's all you want or you can be prepared with you wallet if out of warranty. Keep paperwork incase down the road there is a recall and recoupe your money later. Or maybe nothing will happen at all and you'll have a uneventful vehicle ownership. Certainly not going to worry about something that hasn't happened yet. But then I only have 163,000+ miles so far and shooting for 300,000. 🤷
