OT - Old Tractor Tires
Old Aug 23, 2024 | 08:10 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
Working on an historic relic of a tractor with the almost 90 year old factory original 11.25-24 tires. Yes, 11.25-24, a prewar tire size. I believe as tire standards progressed, this is equivalent to 13-24 and finally 14.9-24. Can anyone confirm this, and what are some suggestions for finding cost effective tires and tubes?
Old Aug 23, 2024 | 09:02 PM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
The 1949 edition of the Tire and Rim Association Annual lists the 11.25-24” implement tire appropriate for either a W-10H or W-8H rim. The sizes you list are correct for a 2” wider rim. I looked on eBay and sellers have the 11.25-24” listed. Stu
Old Aug 23, 2024 | 09:17 PM
bmoran4's Avatar
bmoran4
Stu, these are not implement tires. These are the main rear tires of an English Fordson Model N Tractor with French & Hetch round metal spoked rims.
Here is a (not the best angle) picture:
They are very much like the wheels pictured here on tractor data:
https://www.tractordata.com/farm-tractors/002/7/7/2774-fordson-fordson-n.html
Old Aug 23, 2024 | 09:43 PM
truckdog62563
Okay, somewhere I have a few old French and Hecht references that I can dig out tomorrow. Are the rims a lot different than other ag rims? Do they have a unique tire bead and seat, and does it need a specific tread profile? It would seem that the same width issue would apply as any other ensuring that the tires are appropriate for the rims. Stu
Old Aug 23, 2024 | 09:55 PM
bmoran4's Avatar
bmoran4
I know that the current tread pattern on my tires is extinct. I would like some sort of tractor tread.
As for the tire size compatibility, I was reading this:
https://www.farmcollector.com/tracto...ound-to-tires/
Also, Miller Tire combines the sizes:
https://www.millertire.com/categorie...4-9-24_-13-24/
Then there are threads like this where nobody can agree: https://forums.yesterdaystractors.co...eeded.1545971/
As for profile, seat etc... I do not know. The current tires appear to be the original Firestone if that means anything.
From a period Fordson publication:
Old Aug 24, 2024 | 07:50 AM
pintoplumber's Avatar
pintoplumber
There’s an antique tractor tire company in Ohio called M E Miller tire. Perhaps you could find something there? Dennis
Old Aug 24, 2024 | 07:52 AM
bmoran4's Avatar
bmoran4
Already linked them above stating they combined 13-24 and 14.9 sizes, but could not confirm that the older 11.25-24 is the same.
Old Aug 24, 2024 | 08:33 AM
52 Merc's Avatar
52 Merc
Old tractors are fun. At least yours is a rubber tire version. Good luck with your tire quest.
Old Aug 24, 2024 | 08:40 AM
52 Merc's Avatar
52 Merc
Not to hijack the thread, but when I was looking for the steel wheel pic, this one was in the list with the custom panel body. I just couldn't resist.
Old Aug 24, 2024 | 09:09 AM
truckdog62563
The French and Hecht reference I found is much too new to apply to your tractor. No help there. The guy in the first linked reference describes using uniform tire size molds over time with (as I read it) progressively wider carcasses thus improving performance. That would strike me as only of use to you if you had the ability to use progressively wider demountable rims. Your spoke wheels have fixed drop center rims of unknown width. Not sure what to make of the other discussion thread.
Rim width is the critical factor. If your tires are 11.25-24”, the below 1935 Tire and Rim Association charts again show an 8” rim. Your picture shows the rim to be a drop center one piece, as in the schematic diagram. And, assuming yours are like the diagram, have a 5° bead seat profile like more modern tires. So verifying rim width of your wheels should settle it. Stu
Edit - I must have read that first linked article eight times and feel more confused each time I read it.
Old Aug 24, 2024 | 07:29 PM
bmoran4's Avatar
bmoran4
Thank you for all that information @truckdog62563 !
Crudely measuring, I believe the rims do indeed have a nominal 8" width. So what do I (or more realistically, a shop) put on them?
Yeah, I know the casting number of HC129 was used on multiple wheels of multiple sizes.
Old Aug 24, 2024 | 09:28 PM
truckdog62563
One thing to do is to call the author of the article you linked and discuss it. He listed his phone number. The other is to rely on your tire vender. A reputable local ag shop you’d think would have seen similar situations over the years. If a size larger than the 11.25-24 is recommended and it turns out wrong they should be able to make it right. Stu
Buckstop
Nov 27, 2021 08:03 AM
Podaso
1997 - 2003 F150
Dec 20, 2010 01:13 PM
Jermafenser
27
May 17, 2010 02:34 PM
paver1960
Sep 12, 2003 06:08 PM
