Front Center Console Sliding Door
Old Aug 23, 2024 | 04:19 PM
F2502011's Avatar
F2502011
The sliding door over the compartment that houses the wireless charging and USB A and C ports used to stay open once pushed forward but now it won't stay and just slides back closed. Not really wanting to take it into the dealer for this any ideas?
Old Aug 25, 2024 | 10:02 AM
F2502011's Avatar
F2502011
No one has or has had this issue? Wondering if I can maybe adjust something and get it working correctly again?
Old Aug 25, 2024 | 10:28 AM
4wd6.7L's Avatar
4wd6.7L
I had an issue 1 time with that door in my '19, but the symptom was different. Mine jammed up. I used a little force to free it up and it hasn't acted up since. Your's might require disassembly to diagnose and fix. I don't know what all is involved in getting it apart, if under warranty I would be more inclined to let the dealer fix it. If you decide to take it apart and find that it needs to be replaced, it will be out of pocket at that point.
Old Aug 25, 2024 | 02:46 PM
jimzpsd's Avatar
jimzpsd
Exactly, if this is on the new truck in your signature...don't touch it. Have the dealership repair it through warranty. (You didn't say what year truck so I'm just assuming here).
Old Aug 26, 2024 | 10:14 AM
jared.gourlie's Avatar
jared.gourlie
My ‘23 has done this since day 1. I don’t really use the compartment much except to store charge cords and I have my dash cam routed to the USB port in there. It used to only close when I hit a bump but now it’ll just randomly close so I leave it that way. It’s not worth taking to the dealer in my opinion unless you’re regularly using it.
Old Aug 26, 2024 | 12:04 PM
bpounds's Avatar
bpounds
Question for the OP, when you would close that door, did you pull it closed, or did you push it forward and let it close itself? It is supposed to be a push to open, push to close device.
Asking, because that wasn't obvious to me and I pulled it closed while at the dealership picking up the new truck, and the salesman showed me how to do it. I'm sure doing it wrong would eventually cause the latch to fail.
I'd probably just whittle a wedge out of wood and shove it in the groove to hold it open forevermore.
SMW
Aug 18, 2022 04:57 PM
02X
Jul 26, 2012 03:16 PM
LRSTony
Nov 5, 2010 02:24 PM
QckSlvr
Sep 16, 2009 04:08 PM
SampsonRealty
Sep 25, 2001 08:09 AM
