when to change coolant
Old Aug 23, 2024 | 09:34 AM
fordman19762003's Avatar
fordman19762003
Normally I change my coolant at 50000 along with all the other fluids and plugs. I see the newer yellow Mountain dew colored coolant has a 10yr/200k mile life according to the book but I won't run it that long. What mileage are you guys changing your coolant at? Even though I don't tow much I consider my trucks usage severe because of the short distance drives, the dusty conditions, and the hot/cold cycles.
ETA. The truck is a 2019 F250 with the 6.2.
Old Aug 23, 2024 | 09:46 AM
PatrickStapler's Avatar
PatrickStapler
I always did 50K miles on my '15 F250...along with the front and rear diff's, transfer case, and trans. I tow quite a bit. I see no reason that I would change that frequency on my '23 F350.
Old Aug 23, 2024 | 09:52 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Waste of money and good coolant to change it early, it's not like oil that gets used up quickly.
Old Aug 23, 2024 | 09:53 AM
bent-1's Avatar
bent-1
I do 50k or 5yrs on coolant
Old Aug 23, 2024 | 10:09 AM
rufushusky's Avatar
rufushusky
OAT based coolants have very long service lives, OTR trucks run them for hundreds of thousands of miles, even in delivery truck applications. There is no silica to fall out of suspension, unless the system has been contaminated there really isn't any reason to change it. Wear rates in a cooling system are a fraction of what they are in even in a transmission, transfer case or diff. I have 120k on mine with what appears to be OEM coolant and I don't plan on change it until I am north of 180k miles, a water pump dies or a hose pops a leak.
Old Aug 23, 2024 | 11:25 AM
scraprat's Avatar
scraprat
Top Answer: 5
161,000+ miles on the '21' sometime in the next 40k miles I'll get it done.
Old Aug 23, 2024 | 12:31 PM
ejb69's Avatar
ejb69
Just when I replace a water pump or hose or open the cooling system for any reason. With that said I seldom keep a vehicle for more than 150, 000 miles. If you plane on keeping a vehicle for ever ,it’s probably best to change every 50,000.
Old Aug 23, 2024 | 01:03 PM
WXboy's Avatar
WXboy
Timely post. I'm going to hit 100k soon and was planning to change my coolant when I install the block heater since I figure I'll loose most of it when I remove the freeze plug. I called the diesel shop that did my diet plan and DPK last week and the owner of the shop said "don't worry about changing it". He said especially with no EGR it's really not important to change it until I have issues with it. Hmm....
Old Aug 23, 2024 | 01:35 PM
bigwin56f100's Avatar
bigwin56f100
yes same here. I recently sold my 2005 f150 with 130,000 miles and I never changed it and never had the system open. Never changed the brake fluid and Never changed the front differential fluid or the transfer case. Did do the rear end several times and the transmission several times. Probably should have done the transfer case.
did change the PS fluid only because I had a line go bad and leak
Old Aug 23, 2024 | 02:35 PM
cmk1's Avatar
cmk1
Every 30k along with all the drive train fluids.
Old Aug 23, 2024 | 02:43 PM
scraprat's Avatar
scraprat
Top Answer: 5
Nothing wrong with over doing it and if it makes you sleep better but what a waste of good fluids.
Old Aug 23, 2024 | 03:34 PM
cmk1's Avatar
cmk1
They served their purpose. Not a waste.
Old Aug 23, 2024 | 03:59 PM
Zork's Avatar
Zork
These fluids and fluid changes are so cheap (if you do it yourself), it's really a no-brainer to do it even more often than the owner manual suggests.
It's also a great opportunity to check the vehicle out for other things that might be amiss
Nothing like maintaining your work vehicle/equipment yourself at yearly intervals.
Old Aug 23, 2024 | 04:25 PM
cmk1's Avatar
cmk1
exactly. It’s why I hand wash as well. I can see new scratches or painted chips and take care of them quicker.
Old Aug 23, 2024 | 05:24 PM
scraprat's Avatar
scraprat
Top Answer: 5
Why change fluids when not needed other than something to do? You believe parts will last longer or fluids are breaking down? What parts are failing when following recommendations?
If a person is beating the snot out of a vehicle and mud bogging to the doors I'm all in on frequent changes but for the majority asphalt queens. No need....but that's just me and I rack roughly 45-50k miles a year with off road conditions.
