Sponsored by: Real Truck
Transmission troubles 2002 F250
Old Aug 23, 2024 | 08:40 AM
MushinMan's Avatar
MushinMan
3rd Gear
Hey there
I'm having some transmission woes with my 2002 F250 w/ 5.4L Triton automatic transmission.
The issue I'm having is as follows: i sprung a leak between the rear of the engine and the bellhousing, got some stop leak for it and trans fluid to fill it back up (as per recommended by a local shop). Which seemed to do the trick, but quickly turned into whenever my transmission gets warmed up after driving a couple of miles, there's no more go. I can hit the gas and the engine will rev up, but it's like I'm in neutral. When putting it back into park, there's a whine that comes from the transmission.
Has anybody had this happen? I'm guessing I'm SOL and will end up needing to either have the tranny rebuilt or buy a replacement one, but any guidance or advice is greatly welcomed. I do most of my own maintenance but this is a little out of my wheelhouse and capabilities
Thanks in advance!
Old Aug 23, 2024 | 11:17 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Is it low on transmission fluid? Check it warmed up, in park, engine idling.
Old Aug 23, 2024 | 11:25 AM
MushinMan's Avatar
MushinMan
3rd Gear
No it's not low, it was right at the top of the hashmarks on the dipstick
More work than needed
Feb 6, 2024 03:21 PM
Borgia
Jun 13, 2018 01:59 PM
F250MSgt
Nov 14, 2017 11:03 AM
BB 460
Jan 23, 2010 06:13 PM
Salblock
Aug 5, 2008 11:53 AM
