F250 Trans issues
Old Jan 23, 2010 | 05:52 PM
BB 460's Avatar
BB 460
F250 Trans issues
Got a '90 F250 with a 460. Not sure if its got a C6 but thats beside the point. I recently began to get a transmission fluid leak commin from somewhere near where the trans meets the engine. Ive let the engine run and warm up, and shifted through the gears without issue, so it must only happen when we drive her. If anyone has any ideas, they would be much appreciated.
Old Jan 23, 2010 | 06:08 PM
Jigger2020's Avatar
Jigger2020
pull the inspection cover off the front of the tranny & see if it is wet in there (with the engine turned off) if it's wet check the drain plug in the torque if it has one,if not then the front seal is leaking & the tranny has to come out.You can try Lucas transmission fix & you might get lucky,Gigger
Old Jan 23, 2010 | 06:13 PM
BB 460's Avatar
BB 460
Thanks, ill try that tomorrow
