Contaminated fuel system
Old Aug 22, 2024 | 05:19 PM
90LBT's Avatar
90LBT
Well gents, long story short after doing a deep dive going through my new-to-me 04’ 6.0 I’ve come across the wonderfulness of there being gas in the truck. That’s right, gasoline. I pulled the filters and holy moly does it smell like 91 octane. Seems no wonder the truck didn’t start for the last owner. I’m guessing next steps are drain the tank, replace the o-rings at the upper filter, and replace the HFCM (mine has the fuel heater in it anyways). Thoughts? Tips? How fubar is this engine now?
Old Aug 22, 2024 | 05:25 PM
bismic's Avatar
bismic
You are probably ok. Just pump out as much as you can. You can disconnect the discharge line from the HFCM and put a hose on and run it to a bucket. If it were me, after pumping out as much as you can, I'd put a sump in it. Installing the hole for the sump will drain most of any fuel leftover from the pumping.
Old Aug 22, 2024 | 07:07 PM
90LBT's Avatar
90LBT
I am considering a sump and using the HFCM while using the stock fuel return just to eliminate the potential issues with the fuel pickup
Old Aug 22, 2024 | 07:16 PM
bismic's Avatar
bismic
That is how I did mine.
Loftatsea
Apr 21, 2019 01:07 PM
Gryphon1962m
May 18, 2016 02:03 PM
Cobratodd
Apr 22, 2010 10:49 PM
team5150
Feb 6, 2010 08:34 PM
jas67
Oct 1, 2009 04:03 PM
