Heated throttle body
Old Aug 22, 2024 | 03:57 PM
Junktownbill99's Avatar
Junktownbill99
Always gotta be something...
I have been losing coolant, which I chalked up to a dirty system I recently flushed. Just today the leak got bad enough to create a big puddle, and I was able to find it.
It was that short coolant line under the TB, I went to remove it, and it snapped the elbow on the TB. Is there a good way to repair this, or should I just bypass it permanently? I won't buy a new TB if I can avoid it, I just spent a whole lotta money on this thing, and I'd like to at least save a little.
For the short term, I just bent the hose from the top of the TB over.
At least I found my leak, yay?
Old Aug 22, 2024 | 04:19 PM
rla2005's Avatar
rla2005
Plenty of folks have bypassed the throttlebody coolant ports with no reported issues.
Old Aug 22, 2024 | 05:26 PM
Conanski's Avatar
Conanski
This heating circuit helps prevent icing of the throttlybody in colder climates, if you don't live in the north there is nothing at all wrong with bypassing it and even if you do you may never experience a frozen throttle if you don't do much hwy driving.
Old Aug 22, 2024 | 07:31 PM
Junktownbill99
I do live pretty far up north, at about 2000 feet. I do some highway driving, if I want or need to go anywhere. Freeway driving, only sometimes.
Old Aug 23, 2024 | 10:05 AM
1Butcher's Avatar
1Butcher
Bypass it. You could always look for a used/cheap one while it's bypassed.
Old Aug 23, 2024 | 01:16 PM
Hit Man X's Avatar
Hit Man X
My pal is working in SLC and lowest area is 4000ft, he has never had an iced over TB on his winter beater there. Heck my 4.9 is not heated either from the factory.
Bypass it and get on with life. I think the small port on the water outlet is just a 1/8" NPT.
Old Aug 24, 2024 | 07:22 PM
TobyB's Avatar
TobyB
It's to prevent icing in wetter climates when it's cool, sopping wet, and the engine's not yet warmed up fully. Or working hard.
They were retrofitted under warranty on early engines. Earlier versions had a heat riser off the manifold, a thread a few weeks back explained.
The legal concern was that the throttle plates can freeze open, leading to runaway that, once you wreck,
has no visible cause, since the ice melts out before the forensics team gets there.
How often it happens? Around here, where it's cool and wet, not infrequently. I bypassed a leaking one
once (on a Mitsu) and it would pretty regularly ice up in commuting when I dropped down onto the floating bridge across Lake Washington.
If you're ready for it, it's not often fatal, but it can surprise you when it happens. Or when the thing ices up
so badly that airflow's restricted. You get good at switching off, coasting as long as you can get away with, and then restarting.
It usually melts out by then.
t
Old Aug 24, 2024 | 11:11 PM
samuel4wolfpack's Avatar
samuel4wolfpack
Hmmm, I never knew you could bypass those coolant lines on the TB.
Old Aug 25, 2024 | 04:29 AM
AuroraGirl's Avatar
AuroraGirl
You just need to either loop the loop before the TB, or plug the source. Like a heater core.
Old Aug 25, 2024 | 04:34 AM
AuroraGirl's Avatar
AuroraGirl
Steve83 (bless his hateful, intelligent heart) says the 4.9 likely doesnt have one because of the low volume of air that goes into it
Which , combined with the exhaust manifold placement vs the intake where it wraps around , so the throttle isnt far from that source, makes a little bit of sense. But If you were to find the ideal conditions and start WOT i could see it possible lol
nhudgens1692
1997 - 2003 F150
May 20, 2025 11:39 PM
mwellington
Jul 28, 2021 07:04 PM
'91 Silver Devil
Jul 31, 2007 09:42 AM
luke_trash
Dec 30, 2004 09:44 AM
rsmack
Aug 31, 2004 12:12 PM
