2003 6.0 faltering
Old Aug 21, 2024 | 07:50 AM
Sprocket1954's Avatar
Sprocket1954
6th Gear
2003 6.0 faltering
My 6.0 runs ragged if started Hot. It will shift terrible. What could cause this?
Old Aug 21, 2024 | 08:05 AM
bismic's Avatar
bismic
You are going to need a scan tool to avoid guessing.
https://www.ford-trucks.com/forums/1...g-process.html
Old Aug 21, 2024 | 10:26 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
It could be so many things that we don't have a starting point without a little bit of hard data. About equal chances of it being computer/electrical/sensor as hard part failure. The shifting could be caused by low power output from the engine and might not be something that actually needs direct diagnostic, or the entire mess could be a power supply problem.
Old Aug 21, 2024 | 01:43 PM
Sprocket1954
6th Gear
We changed the IPR and the ICV. Scan tool shows nothing.
Old Aug 21, 2024 | 02:04 PM
Sprocket1954
6th Gear
. The fuel water separate mod light is on. Changed the filters and wiped out the case before installing new one.
Old Aug 21, 2024 | 02:22 PM
bismic's Avatar
bismic
The scan tool will provide the data we need. We wouldn't ask for it if a scan tool didn't provide it and it wasn't important. You have already guessed (and I know how expensive the parts are that you installed - unless you bought cheap counterfeits). If you do not want to spend more money guessing, we need the following:
Operating Conditions:ESPECIALLY If it is a Crank No-Start, begin by filling in the data requested below:
KOEO:
  • ICP sensor volts
  • FICM MPower
  • FICM LPower
  • FICM VPower
  • IPR % Duty Cycle
Cranking:
  • Cam/Crank Sync
  • FICM Sync
  • FICM MPower
  • FICM VPower
  • FICM LPower
  • Injector Pulse Width
  • Mass Fuel Desired
  • rpm
  • ICP sensor volts
  • ICP pressure
  • IPR % Duty Cycle
  • v-reference voltage
Old Aug 21, 2024 | 03:19 PM
Sprocket1954
6th Gear
Okay,It'll take some time to collect this as I use our new 450 mostly.But the 350 runs great on cold starts. And it is my favourite truck.
